RDB85
Trainee
I’m looking to buy some PVC Conduit for some security lights rather than clip the cable. We don’t use it in work. But I know I need 20mm conduit but would I be okay using 20mm inspection elbows? I assume they just fit inside?
Yep and saddles, box lids and screws and if outside some waterproof gaskets,
Only thing I might add is that 'waterproof' gaskets don't waterproof. By all means fit them but when designing an external system always assume water will get in. Allow for drainage, by for example, fitting a terminal box at the lowest point with a small drainage hole. Do not enter lights and accessories from the top, come in from below or the side, and keep all joints out of conduit boxes.
what's wrong with inspection elbows? how else do you come through a wall and then 90 degrees (up/down/left/right)? do youm bent the tube and have it sticking 4" off the wall?
Me, I use a back entry on an end box and shoot off from there, better than an Inspection elbow I reckon, but each to their own I guess.
Careful with the springs. Get one from the same supplier as the pipe you are using. There can be discrepancies between the inside diameter of different manufacturers. so it it can either be too tight to push in, or too loose and cause wrinkles.
whoever said bending the pipe with a spring would be more economical.... it depends how good you are at bending.
I see nothing wrong with using manufactured bends for neatness. All uniform radii, all the same.
I’ve ordered the pvc adhesive. The diameter is 20mm but the elbow and inspection bends and even the end boxes don’t fit inside the conduit. As I wanted to get it all measures and test fitted before using adhesive.
As the tubing doesn’t fit over them I assume you would make some cuts in the end to make the diameter smaller?
???? The pipe goes INSIDE the port on the fittings, it should stay there on its own, no need to cut anything, it just pushes in.
I know it should do this doesn’t it’s the same diameter. So it doesn’t push inside. Not sure if it’s the conduit or the fixings I’ve bought. The fixing are a brand make and the conduit was given to me.
I will get a photo to show you what I mean. I assumed that the fixings should fit inside, so I was a bit confused when they didn’t and thought do I need 25mm tubing.
RDB85
Trainee
Liverpool
United Kingdom
Trainee Electrician
PVC Conduit Question
RDB85,
timhoward,
