R1 R2 on Radial circuit | Page 2 | on ElectriciansForums
Discuss R1 R2 on Radial circuit in the UK Electrical Forum area at ElectriciansForums.net
TheCodboy
Newcastle
Just installed a small length radial circuit. Total length from board no more than 2 meters. Halfway along is a FCU and a double socket at the end. Linked line and earth and tested at the socket and got a R1 R2 reading of 0.10 ohms,hit the switches to confirm polarity and the reading stays the same. Am i missing something here? surely i should loose continuity and the meter should go full scale, just like when testing R1 R2 on a lighting circuit? Am i having a proper brain freeze moment here??
Thats correct yes
Thats why you can't prove continuity by switching the socket switch on and off, you never mentioned in your original post that the FCU was for something else other that feeding the socket, which as others have pointed out, a rather odd thing to do.
Reply to R1 R2 on Radial circuit in the UK Electrical Forum area at ElectriciansForums.net
Often, but not always: 543.2.9 Except where the circuit protective conductor is formed by a metal covering or enclosure containing all of the...
I was at the other end of the results spectrum today. As I was driving home I had a call from my "Mrs Richards from Fawlty Towers" lady, very deaf...
