I'm sure AC units (air con???) like fridges/freezers can trip RCDs, there aren't a few of these units and rfc's and lighting all on one RCD is there?
A tripping RCD does not always mean there is a fault present, alot of modern office equipement have electronics that have a designed leakage current to earth hence the term High Earth Currents which must be accounted for in design when you have a no' of computers or light fittings with electronic ballasts, in the OP case i would first do a earth current test to establish if there is already a high leakage which may be related to designed leakage as opposed to fault leakage.Looks like it's going to be out of hours testing then. The RCD tripping shows there's a fault somewhere which needs identifying and rectifying, I personally would not have left the circuit without RCD protection as the designer deemed it necessary to have it.
Even a quick test taking 15 minutes could highlight problems and reduce the amount of downtime the office has. Protection is there for a reason.
No worries lol.Very true mate, trying to read a post and reply with two screaming kids and a nagging wife running around doesn't help...
Why not call an electrician?
I think maybe you are out of your depth with this, and walk away now or get someone with more experience to help you.
Are you doing the work or just making enquirys 2Bobsparky ?
What about lights being included as apart of the RCD protected circuits? Isn't this cause for concern? Why did the designer include lighting?
Are lights only likely to cause RCD tripping when a lamp blows or can their componetry do it too?
As ive already mentioned i suggest you read up on the working of an RCD and what situations would cause them to trip, rcd's under the 17th it is usual to have an rcd covering all circuits in some form or other, there are exceptions but you should already be knowledgable in this area if you are doing this kind of fault finding, no offense meant here when i say you seem to be lacking knowledge in some basic areas that i would expect an electrician to have, we will try help where the situation has caused you confusion but with re' to replies to this thread you seem to lack knowledge of how rcd's function, designed high current earths, reg's re' rcd protection and when its needed as well as when it can be left out.
Its the fact your struggling with knowledge in several areas which you should already know, if you inform us better on your background we can answer your queries better, but all the help your getting your are answering with another question.
So what is your background, are you apprentice, qualified, etc etc then from there we can head you in the best direction.
