replacing class 2 fitting, no visable earth. | Page 2 | on ElectriciansForums
Discuss replacing class 2 fitting, no visable earth. in the UK Electrical Forum area at ElectriciansForums.net
Hi all need a little clarification.
Customer wants ceiling light fittings x 2 replaced with class 1 fittings. Lighting circuit is earthed at C.U. and class 1 wall switches, and at one of the lights. There appears to be no earth at the second light( just x2 black singles & no sign of the loop). Note both lights are in same room about 3meters apart but are switched seperatly. I have not been into the loft as of yet, there may well be a junction box_ containing the earth & loop. If so no problem.
If no earth is present I plan to extend the earth from the other light point ( same lighting circuit)
if I have understood the regs correctly the min size CPC will be 4mm with no mechanical protection or 2.5mm with mechanical protection. Would hate to try and terminate 4mm into a light.
Note only 3 meter straight run so conduit/trunking to provide mech protection.
Reply to replacing class 2 fitting, no visable earth. in the UK Electrical Forum area at ElectriciansForums.net
We just left it as it was, again the customer didn't seem too bothered, dont think she wanted me digging any further.
I find with these so called 'class 2' metal light fittings which are basically class 1 fittings with a crappy supposedly double insulated joint...
    • Funny
I completely agree. In real-world terms it will become less and less of an issue, as long as the lamp isn't broken exposing live parts.
2 3
8K
I've done the board change on this now, what a lash up it was before, old 16th board hacked into a dual RCD one, think they have taken the main...
