Probably a reasonable call to make, outline the "issues" and then how you intend to deal with it, seeking their views .... that way they can tell you have thought about the "job" rather than assuming they will give you the answers.
A bit like using this forum... outline issues, suggest your solution (as you did) and then respond to points raised - which you have - and this is the best way to get the most out of the "virtual" team.
Which scheme are you with?
working through NICEIC towards DI
butchtaylor909 some of the questions. that asked on this forum
we can not do the job for you .
we can only give you advice may be one of the sparks on this forum could call to the job in question and give advise.
If you can prove the tube in the wall is effectively earthed then a non metal sheathed cable can be used without additional rcd protection. You need to assertain whether main protective bonds are required in the garage, if not you can ignore the separate 10.0 cpc requirement. I would avoid using YY, CY or SY cable because it is not recognised for use in this country. 10.0 T&E is fine with a separate 10.0 if required for main protective bonding.
I never wanted anyone to do the job for me,
I
had a problem,
I
had come up with a solution,
I
just wanted some advice as to if there were any problems with doing it that way.
A simple yes mate that's fine or no mate have you considered x,y,z... would do
Thank you. i had planned to test the conduit next time i am on site. cannot remember if the sink had plastic or metal pipes, so had planned to be checking that too.
last time i say YY cable was during my 21 years in the military so i know about it but was not sure about its domestic use as i am still relatively new to this.
Avoid all those YY, CY and SY cables even though you see it installed everywhere.
extension to existing circuits, replacing accessories, CU change, full rewire, first and second fix on a renovation. simple stuff, nothing where i have had to join cables at anything other than an accessory, which is why i needed to ask about this job, not because i did not know but more because the more i thought about it the more i doubted myself.
not currently i was doing work with a NICEIC electrician that lived nearby until he gave up due to ill health last week.
currently sat at home twiddling thumbs and doing what ever jobs i can get
Agreed sy,yy and cy cables are not made to a British standard and you would have to depart from bs 7671 if using them for fixed wiring.
They are commonly used for control wiring and aircon.
The on site guide warns about using such cables.
From memory they are made to a British standard, BS EN 50525 iirc.
Bury
Website
http://DTElectrics.co.uk
Business Name
DT Electrics
Rewiring to a garage
Thread Tags
butchtaylor909,
Dave OCD,
