B
bigdavs83
Need to read the whole posts I was stating in my experience with the schools contract if it is left after every pir as a limitation. Slightly off the OP subject to be fair.
but do you test every socket?I would test every circuit but may only open a few sockets switches and lights on eachcircuit . I wouldnt open every socket and light fitting if the viewed ones looked good. As long as test are ok!
thanks guys
thanks guys
then he is not testing 100% as he agreed with client.So you are applying a limitation then
forgive me if Im wrong but doesnt an eicr also state a function test?
How can you perform a function test if you dont check all spckets and it takes no extra time to do r1+r2 then zs at each socket.
(use plug in tester rather than taking fronts off)
I will hold my hand up and say with this firm we have never done a 100% test and inspection.So you are still not inspecting 100% how does a plug in tester check the integrity and tightness of the terminals at a socket
It is very easy to spout about doing a 100% I & T but I'm begining to wonder if people have different interpretations of 100%
There always will on every I & T be some compromise as to completely 100% check one RFC with 20 sockets on would take some time on a large site with a few RFC's of similar size how many circuits are you going to I & T in a day as the customer watches the costs spiral
Yes all sockets would be checked but not opened. A plug in tester would be used. Would you open every light to check connections if the last fitting has good connections?
what about stage lighting multicore swa. Would all of this need testing there is. 4 poles with stage lighting and 15 amp socket outlets all connected to a dimming panel
Davesparks sound advice however can you always trust previous test results? Especially if it's done by some other company of which you know nothing about.
the problem is more people selling the service as a 100% test which missing bits out isntGo on then, how do you go about testing the stage lighting installation?
How do you carry out a Zs test on a hardwired dimmer? Or a patch able system for that matter?
Bearing in mind stage lighting installations for everything from school halls to Glastonbury festival are my specialist subject![]()
I was going to ask about the stage lx installs earlier on but got distracted. You can't do the standard tests out of the book as the dimmer effectively forms a DB (24 ways of dimming at 10A each) but each way is controlled by a dimmer so you can't just plug a loop impedance tester in the end of it and get a sensible result!
But then some testing wombles will code the whole lot C2 due to it having 'obsolete' plugs and sockets! We use 15A round pin sockets to distinguish dimmer controlled sockets from regular sockets.
