SDS drill sparking.. | on ElectriciansForums
Discuss SDS drill sparking.. in the Electrical Tools and Products area at ElectriciansForums.net
mattg4321
V.Nearly Esteemed
South East UK
As above, SDS drill sparking and intermittently down on power. Sparking between brushes and commutator.
Brushes and springs seem ok, but have quite a curved surface at point of contact. Loads of meat left on brushes.
Will changing brushes fix it or is it dead?!
I am not sure if he means the commutator is curved or the brushes. If the former then it's knacked. If the latter it's still knacked as the commutator must be rough to cause the brushes to curve.
Brushes are curved.
Yeh I had this pic that they were worn on the edges and not meeting the commutator. It's a well known fact if you try to sell a drill in a second hand shop they switch it on and if there are sparks on the commutator they will not buy it. Of course they are curved as they contact the commutator but the sparking usually means Knacked. However I have been known to clean the contact points and new brushes and hey presto problem solved. I am not for chucking tools unecassarily
If the brushes are sliding freely in their tubes, the copper braid hasn't caught up somehow, restricting their movement, and it's still sparking excessively, then it's knackered.
a bit of sparking is normal. if the armature is knackered, then generally the drill runs slower and sometimes stinks of dead fish. a new armature can be got for around £30 - £40 for a lot of drills. expensive drill can be worth the repair.
Pictures and video ad promised. Think it's dead?
  • [ElectriciansForums.net] SDS drill sparking..
  • IMG_9676.MOV
    7.3 MB
Reply to SDS drill sparking.. in the Electrical Tools and Products area at ElectriciansForums.net
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
Sorry i think i may have confused the situation - "relay" is a general term in this context. The starter "relay" nowadays is usually located...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Thanks for the advice.
Trending Electricians Tools
New job, new tester; Megger 1741+, those that have one; anything good/bad to report? Work also trusting me with a Flir E5 magical heat-reading...
96K
Absolutely correct they hold water, shrouds are totally unnecessary. 20s is 24mm spanner, 20 large is 30mm spanner.
45K
If that little thing, plugs your butt, you better eat slowly. 🤣
2 3 4 5 6 7 8 9 10 11 12 13 14
41K
B
I'd say everyone has knowledge gaps in their area of electrical work I know i have quite a few i work on to fill them in
2 3 4
29K
I too have been tempted.. I’m buying for my son. He’s in his2nd year at collage and looking for apprentiship. Sadly it’s almost impossible in my...
25K
Of course. “Ye canna change the laws of physics” EDIT. oh blimey, I just spotted the date of the OP. ? Thank you very much @Lord lee jan You...
23K
Only way to do it in a tight space
21K
The display on the Mft pro is not very durable mine is broken already 😡
21K
Only lawyers , solicitors and dodgy chat up lines charge for picking up the telephone 🙃
2 3 4
20K
J
I'm not entirely certain as it's very tough, but brittle when cold.
2 3
19K
nicebutdim
N
