shock!! no trip! | on ElectriciansForums
Discuss shock!! no trip! in the UK Electrical Forum area at ElectriciansForums.net
E
eganelectrical
When I wired my ccu I fitted all rcbo's. and tested all trip times etc. all passed!! In the garden mixing cement a few weeks later and water got all around the extension lead near the plugs! I didn't see this because it started getting dark! But Jesus I felt it with a rattle as I unplugged the mixer!
Went in the house and Rcbo for outside sockets still on! Checked trip times the next day and all still fine!! Surely this should have tripped??:mad:
Yeah that's odd would have thought the rcbo would have seen the imbalance in current they are normally quite good :s dodgy rcbo by sounds of things but you say you trip tested it and it tripped in
Good time ok?.. Sure there will be a lot smarter guy to give a better explanation I'm sure.
Did you check the trip times at the socket or at the rcbo in the board, this is sometimes a mistake by some sparks, as the earth may not be conneted in the socket, where the mixer was plugged in, or maybe the mixer hasnt a good earth.
Just a thought..
Extension lead reel was probably plastic, so being wet probably didnt give a good enough path to earth, until you touched it, then you must have got less that 30ma.
would you be so kind to do it again but put a amp clamp round the live and neutral and let us know the leakage
please don't. I'm only joking
The most painful and only cross body shock I've had was on a circuit with 30ma rcd protection, which didn't trip, but was later tested and passed.
Below 30ma hurts.
All the others have failed to reach the same level of pain.
Just a thought..
Yes mate I checked from the socket! Also tested in from ext lead plug sockets.
Reply to shock!! no trip! in the UK Electrical Forum area at ElectriciansForums.net
Well yes obviously, but if the transformer is indoors and your lights are 50m down the garden then it's very easy to need pretty big cables at...
Thank you, what would be the advice for me to do in this scenario? I've also seen circuits tripped in past from other things such as 1500VA step...
