Socket Tester recommendations | on ElectriciansForums
Discuss Socket Tester recommendations in the Electrical Tools and Products area at ElectriciansForums.net
RDB85
Trainee
Liverpool
I’m looking to build my tools back up after a bit of bad luck. I’ve bought some screwdrivers, cutters etc. I’m just making a list of what I had. I’m just after a socket tester. I’ve seen Fluke now have one that looks very good. I did have just the basic Kewtech.
The new Fluke socket tester is about £50.
There are plenty of options that'll do the job for a fraction of that price.
To add to the above; the vast majority of socket testers detect the same range of faults. Some have an additional RCD trip function, but I'm not sure that's a feature any of us need. No matter the price, I'm fairly certain that none can detect earth/neutral reverse and for that reason I consider their main use to be making enough noise so I can hear which breaker seems to isolate a particular circuit and this isn't a function on which vast sums needs to be spent.
It's unlikely that I'd ever buy an unbranded tester, but nor would I spend more than the bare minimum.
Reply to Socket Tester recommendations in the Electrical Tools and Products area at ElectriciansForums.net
I have the Kewtech that I bought in an emergency when my trusty Fluke that lasted many years gave up. It works! It has single pole testing too btw...
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
Ok I’ll try this when I’m down
When he bought the bank, they stripped out all the metalwork, iron bars etc for scrap. He was left with the cashier countertops… which have been...
I use Xero for invoicing and sending estimates I use a different program (Quicken - not Quickbooks) as I have had it from 2004 and it still...
Trending Electricians Tools
New job, new tester; Megger 1741+, those that have one; anything good/bad to report? Work also trusting me with a Flir E5 magical heat-reading...
95K
Absolutely correct they hold water, shrouds are totally unnecessary. 20s is 24mm spanner, 20 large is 30mm spanner.
45K
If that little thing, plugs your butt, you better eat slowly. 🤣
2 3 4 5 6 7 8 9 10 11 12 13 14
41K
B
I'd say everyone has knowledge gaps in their area of electrical work I know i have quite a few i work on to fill them in
2 3 4
29K
I too have been tempted.. I’m buying for my son. He’s in his2nd year at collage and looking for apprentiship. Sadly it’s almost impossible in my...
25K
Of course. “Ye canna change the laws of physics” EDIT. oh blimey, I just spotted the date of the OP. ? Thank you very much @Lord lee jan You...
23K
Only way to do it in a tight space
21K
The display on the Mft pro is not very durable mine is broken already 😡
21K
Only lawyers , solicitors and dodgy chat up lines charge for picking up the telephone 🙃
2 3 4
20K
J
I'm not entirely certain as it's very tough, but brittle when cold.
2 3
19K
nicebutdim
N
