Sub db | on ElectriciansForums
Discuss Sub db in the UK Electrical Forum area at ElectriciansForums.net
newcastle
I recently put a small 4 way db in a out building fed via a 6mm swa from the house db and i used the job as my annual inspection for napit the inspector said i couldnt use the earth from the house to supply this board without permission from the dno and would have to put in a earth rod even though it had a perfect ze, is this bs or have i missed something?
What rule or regulation did he quote to back this up?
i take it then that due to his thinking you failed your assessment?
- - - Updated - - -
he didnt fail me he just noted it down that a rod was required and he couldnt find it in the regs hence why i think bs
Why not challenge the guy, you should be knowledgable enough to make him see your installation is fine. I know if it were me I would be straight at him telling him it's fine and backing it up also.
Reply to Sub db in the UK Electrical Forum area at ElectriciansForums.net
Merry Xmas to all :D
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
You would treat it as a TT installation.
