Sub db | Page 3 | on ElectriciansForums
Discuss Sub db in the UK Electrical Forum area at ElectriciansForums.net
newcastle
I recently put a small 4 way db in a out building fed via a 6mm swa from the house db and i used the job as my annual inspection for napit the inspector said i couldnt use the earth from the house to supply this board without permission from the dno and would have to put in a earth rod even though it had a perfect ze, is this bs or have i missed something?
If there is no extraneous metalwork/pipes etc, then your not even extending an equipotential zone as such, just extending a source earth conductor. None of these wig's can ever explain why you don't need to earth rod an outside/external socket, it's exactly the same situation when all said and done!! lol!!
Reply to Sub db in the UK Electrical Forum area at ElectriciansForums.net
Merry Xmas to all :D
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
You would treat it as a TT installation.
