Discuss sub main started. in the UK Electrical Forum area at ElectriciansForums.net
no, not as in full 35mm, it's smaller. some later canons are full frame but not sure which. ask geordie, he's got a 30D or a 40D.Is it a Full frame Camera
only thing i don't like about the 10D is the small screen size. think the 30D has a bigger screen, there's a great camera shop in chester, 2nd hand SLRs at good prices.
Our lass has the very same although the SD card port is a bit worn and has a nasty crack at the rear.... :smilewinkgrin:Our lass has a couple of 36D. Lovely to handle and a doddle to use. Easy laid out functions with only 2 buttons to control and brilliant to zoom in on.
hope that's the camera that you are referring to.Our lass has the very same although the SD card port is a bit worn and has a nasty crack at the rear.... :smilewinkgrin:
Reply to sub main started. in the UK Electrical Forum area at ElectriciansForums.net
