surface laying SWA | Page 4 | on ElectriciansForums
Discuss surface laying SWA in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
if you want to hear why else i think it would be dangerous laying it on the ground i would say small animals could chew or tamper with it maybe someone who didn't know what it was could try to remove it along with other dangers witch i can not think of this is why i asked on here in the first place
I wouldnt like to come across a small animal thats capable of chewing through swa lol.
This is SWA were talking about its pretty tough, I wouldn't worry too much if it was on the ground or just below the surface, it will obviously be tucked away around plants and stuff. OP- Just please make sure its properly terminated or it could be seriously dangerous!
Please do not put it just below the surface that is really when it will be at most chance of damage.
I wouldn't like to come across a small animal that's capable of chewing through swa lol.
Rhys, i thought you question was very good and valid, unfortunately you never got many well considered answers. I think you are concerned that an electrician may scare you into an expensive option when cheaper options are available.
i am an electrical consultant and not an electrician and don't get guidance notes from the likes of NICEIC or ECA (which are often very helpful). I understand the comments with respect to fences and each fence should by judged on merit (remembering the electrical installation has a tabulated life expectancy of 15 years).
A cable should be installed in a fixed manner ie to a fixed item such as wall, other structure, ground etc) and installed in a manner to prevent future damage. This would rule out:
1. Laying a cable loose on the ground.
2. To a fence with limited life expectancy or not structurally sound
3. Laying a cable below the surface just below the ground and covered with the likes of slabs.
4. Other variations.
you options:
1. clip direct to a structurally robust wall.
2. Tench or duct (by electrician).
3. Trench or duct (trench prepared by you).
The making and back filling of the trench is very expensive and I would cosider the previous recommendation of preparing this yourself. Ask your an electrician for a cost for trench requirements.
As for trench depths I usually use the national jointing utilities group guidance. (Free download) at 450mm, but this may be lower for a private dwelling (I think 250mm springs to mind but would need help on this one?).
regards
McN41R
Maybe the hanging brackets, used for multiple swa cables in the collieries, were just a mirage
I understand the ability of an swa cable, but it should still be fixed and not laid on top of soil. The installation is for 15 years and not a year or so. You also need to consider movement on cable under fault. There is is no installation method in the British Standard for cables (even SWA) to be installed unfixed on surface of ground, gravelled or not.
Rodents would only be a consideration if using double insulated or similar.
@Des,
hanging brackets are clearly defined in British standard. i could not really see them being used in a back garden. I on made comment to the original intention of the post. Other various was meant with respect to 1,2 and 3 only.
Are you sure?? 450mm may be fine in some instances, but certainly not in most. As for private dwellings, burying a direct buried cable at 250mm is just asking for trouble in the future. Rule of thumb and commonsense comes in very handy here, eg, rule of thumb, depth should be at least 2 X the length of a standard spade or fork, or just state 600mm because that has been the standard depth for direct buried cables since i first came into this industry, ....and that was a very long time ago!! lol!!!
If were talking ducted cable burial, then depth allowances can be made, depending on the ducting material and it's mechanical strength...
The engineers I work with via architects consultancy's insist on a 600mm2 trench, maybe overkill, but they have to ensure they don't get sued for anything, haven't got the BGB with me right now but I always thought 450mm2 was the minimum depth for a live cable, could be wrong, but don't think so.
I am sure about 450mm. 600mm is over design and is a consultant wasting other people's (mostly their clients) money without good reason.
You can always refer to the free download from the national jointing utilities group, volume 1, table 1.
Are you sure it wasn't 2 feet back in those days ?? :joker:
Since we are considering a domestic situation The electricians guide to the building regulations may be more appropriate than a utility supply document.
Reply to surface laying SWA in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I am with you. Their RCD did not comply with the standard. The only one I know that does comply, though I am sure it isn't alone, is the Garo...
An electrician installed a NEMA 6-20 20A 230V outlet in a surface box for me in my garage, on a dedicated 20A breaker. He was even kind enough to...
