uksparks
Hi,
Whats the best way to take 10mm SWA through this wall?
This is one side of it, and the other is accessible as just the metal, no block work in the way, so literally a thin sheet.
I don't usually deal with commercial buildings like this, so would like a little advice on it really.
I need to fix the cable down the outside and someone has suggested a using a bit of tray, but can only use self tappers down the outside.... so cannot get any better fix than that.
I feel I need some form of gland that will look ok and need to seal the hole up, any ideas?
