View the thread, titled "Tell us about your faults!" which is posted in Australia on Electricians Forums.
K
kung
Hi ALL
Just thought id put this one up for all those faults we find.
heres one to kick it off !
Domestic RCD tripped and wouldnt reset cause was a blown low energy light bulb.:D
There you go now for yours !
What is the IP rating of this head?
doing rcd tests today on up and down ring circuits ie separate rcd units with newish newlec multifunction tester with x half ok no trip x 5 ok less than 40 m/secs but x1 tester tripped rcd but no reading less than 200 m/secs due to safety device built into meter indicating test stopped due to greater than 50v present possibly across n to e have lost manual so dont quite know what it means ,any bright sparks out there ?
Call from friend (Tennent) who returned from holiday to find power off on sockets and freezer flooded room.
Just been re wired but landlord unable to get the spark who did the work.
Asked to sort the matter out.
Found fault where joiner put screw into cables while installing cabnet enclosing CU and meter.
Thats a dado rail above the ring final cct cables where the cables run and the CU is a bit of a mess with a old cable left in for the shower!
I have told them not to hang any pictures or shelves just in case!!!
Reply to the thread, titled "Tell us about your faults!" which is posted in Australia on Electricians Forums.
