Terminating SWA glands at both ends | Page 4 | on ElectriciansForums
Discuss Terminating SWA glands at both ends in the UK Electrical Forum area at ElectriciansForums.net
M
markc17
Hey all,
Was wondering if there is any reg that states an armoured cable has to have a gland both ends?
It is a 3 core single phase 10mm so has an internal earth.. ive earthed it the supply end into the board... The cable runs outside along a building then ducks back in through the wall.
The other end is to go into a small Wylex 2 way C.U. in a server room.
My problem is that the CU has a fully detatchable plastic cover, and the only entrance hole is given at the back.. giving nowhere to terminate the SWA. Even if i packed the board off the wall in wood...there would not be room to make it off properly at the back as the entrance hole is prefab.
I know manufacturers recommend proper termination using a gland.. but the armouring is earthed.. and if i hold the cable tight with cleats.. is there any reason that i cannot tape the armouring to the sheath and slot the cover over it, without a brass gland? Perhaps cable tie the top of the cable to the back of the consumer unit?
The room is locked to the public.. and i am the only person that will have anything to do with the board.
I once worked at a company where they did not gland one end of the armoured where it went into air conditioning units... cant find anywhere that actually states whether it is ok to do or not..
First time dealing with a cheap board like this so any advise apreciated..
Mark
I take it back , just looked at the installation instructions !
I likey likey !:clap:
Edit; On further inspection , although it does electrically insulate the enclosure from the gland it also brings a earth potential in to the enclosure .
I know it is essentially the same potential as using a standard gland and paxoline only less labour intensive but still not quite the improvement i had hoped for .
Reply to Terminating SWA glands at both ends in the UK Electrical Forum area at ElectriciansForums.net
You would treat it as a TT installation.
All the lamp post cutouts I've ever seen have a twin swa gland plate built in to the base.
loz2754
L
