Tester probes for use with Wago's | on ElectriciansForums
Discuss Tester probes for use with Wago's in the Electrical Tools and Products area at ElectriciansForums.net
Birmingham
Hello All,
Just wondering which types of tester probes you all use for testing on Wago connectors?
The probes on my MFT and multimeter do not fit through the small hole incorporated in the connector for testing. I am using a very fine needle type probe at the moment but would prefer something a bit more robust.
Any recommendations?
Thanks and ATB
Chris
Kewteck produce a extra skinny test probe for this. I had problems finding them so contacted Kewteck direct and they sent them to me free of charge.
There brill.
I do like the Kewteck tester and accessories.
Thanks for the replies.
I did think about grinding down an old probe, nice to know it's how someone else would do it.
My voltage indicator does the job perfectly, it's when I come to test using my MFT that the problem starts.
Test wise, the most common one is ZS on lighting circuits with neutrel at the switch and ceiling lights that are difficult to reach or have had the earth not connected/cut off.
ATB
Chris
so short out L-E at the light ( power off, of course) then use method #2 as portrayed by richard burns .
[ElectriciansForums.net] Tester probes for use with Wago's
I’m interested in getting hold of some of those super skinny kewtech leads.
But where from?
I can’t find them anywhere.
I find it odd that such things are not readily available?
Reply to Tester probes for use with Wago's in the Electrical Tools and Products area at ElectriciansForums.net
In the UK the safe current for a cable is determined by considering how it's installed, eg under insulation, or buried in a wall, or in conduit...
Hi there. I’m hoping for some advice. I currently run a small limited company that provides IT services, both commercial and domestic so I...
My 2003 Toyota Echo has two back lights in the instrument cluster. One of the lights would flicker if I hit a bump or something. I swapped the...
For the loop impedance test I would expect the tester limits things to no more than 50V for safety, so 250W max, and even then probably only a low...
  • Locked
  • Solved
Therein lies the problem. I see no merit in further circular debate, so will bow out of this discussion.
7K
nicebutdim
N
Trending Electricians Tools
New job, new tester; Megger 1741+, those that have one; anything good/bad to report? Work also trusting me with a Flir E5 magical heat-reading...
95K
Absolutely correct they hold water, shrouds are totally unnecessary. 20s is 24mm spanner, 20 large is 30mm spanner.
45K
If that little thing, plugs your butt, you better eat slowly. 🤣
2 3 4 5 6 7 8 9 10 11 12 13 14
41K
B
I'd say everyone has knowledge gaps in their area of electrical work I know i have quite a few i work on to fill them in
2 3 4
29K
I too have been tempted.. I’m buying for my son. He’s in his2nd year at collage and looking for apprentiship. Sadly it’s almost impossible in my...
25K
Of course. “Ye canna change the laws of physics” EDIT. oh blimey, I just spotted the date of the OP. ? Thank you very much @Lord lee jan You...
22K
Only way to do it in a tight space
21K
The display on the Mft pro is not very durable mine is broken already 😡
21K
Only lawyers , solicitors and dodgy chat up lines charge for picking up the telephone 🙃
2 3 4
20K
J
I'm not entirely certain as it's very tough, but brittle when cold.
2 3
19K
nicebutdim
N
