Time delayed 100mA RCD | Page 2 | on ElectriciansForums
Discuss Time delayed 100mA RCD in the UK Electrical Forum area at ElectriciansForums.net
The time delay is purely protecting the internal tail links in the metal consumer unit.
The consumer unit has 2 30mA rcds in it as stated by the OP I think.
So using a time delay 100mA on a domestic split load board in place of main switch.
Is that what you mean or i may be babbling?
Pretty much; S Type can only be used for a distribution circuit, although I might be wrong? OP was just asking for min/max times of S Type.
Time delayed RCDs are used for discrimination.
If the upfront RCD was not time delay, then a fault which would cause a downstream device to trip would most likely also cause the upfront RCD to trip.
Might as well only have the one RCD for the whole installation.
Reply to Time delayed 100mA RCD in the UK Electrical Forum area at ElectriciansForums.net
Also use a tails gland and clamp if available and make sure tails are secured to a wall. The danger here is a live to earth fault in the Consumer Unit
Good point, I was assuming an up-front RCD is for fault protection within DB, etc, and to cover for a failed RCBO for fault conditions, not as...
