Torque Screwdriver..... | Page 3 | on ElectriciansForums
Discuss Torque Screwdriver..... in the UK Electrical Forum area at ElectriciansForums.net
L
LankyWill
My elbow is out of calibration and i would like to use a torque screwdriver instead, its something ive been putting off but i have finally caved.
What torque screwdriver is everyone using?
A little review would also be helpful
How do you check calibration of a torque driver? Tape measure and a known weight?
You can get torque calibrators. They used to be calibrated springs with a dial indicator I believe. Nowadays they are more likely to be load cells and digital displays.
As far as I know you clamp them to a fixed surface, attached the torque driver set to a specific torque setting and then turn it to check the mechanisms breaks at the specified torque.
One would assume they test at several points across the range of adjustment and possibly generate a torque curve for the tool.
interesting! so who calibrates the calibrator machine?
they must eventually pop to France and try them on the IPK - no kidding they have an official Kilogram weight under glass domes, and if that's lost we don't know what a KG is any more: BIPM - IPK - https://www.bipm.org/en/bipm/mass/ipk/
Surprised @Pete999 hasn’t posted here. He probably has one of each brand
Don't honestly know how you can say things like that Camerabloke, as you know my interest in tools, is a disease, something I have to deal with, it's my disease,so I'll deal with it my way, nuff said?:p:D:eek::oops::rolleyes:o_O
Reply to Torque Screwdriver..... in the UK Electrical Forum area at ElectriciansForums.net
Not used if tor real yet but it has quite a nice fine ratchet action. The forwards/backwards toggle is a bit fiddly to operate and it lacks a...
But why do they want a CU? That won't give them any more available power than they currently have. As it is a 2.5mm SWA cable it is presumably a...
davesparks
