Wago or...... | Page 2 | on ElectriciansForums
Discuss Wago or...... in the Electrical Tools and Products area at ElectriciansForums.net
How do you pronounce Ideal then? If they are going to rip Wago off in every other way they should start saying their name a different way....
I'm in the same boat, perhaps to my detriment, but I just don't trust other push in connectors.
The push fit splice ones that Ideal make have been my goto for a couple of years rather than crimps. Only now have Wago caught up with an option with their through lever connectors....
[ElectriciansForums.net] Wago or......
I use the 221 but for push in connectors I use HellermannTyton.
I use the term 'push in' to describe all such connectors, but didn't know Hellermann made these. Interesting that their lighting connectors look identical to Wago 224
Always liked the idea of these connectors, but have read about more than one issue with Ideal splices. Maybe they were poorly fitted, but this is the reason why I'm generally hesitant to use anything other than Wago.
These were the cause of a ring final circuit continuity fault, ditched them fault gone. Awful things.
They've always seemed a fairly good fit when I've tried, though there is the issue of fixing them in place, which you can't do in the same way as a usual Wagobox. I don't like the blue Ideal boxes much, they don't work well with anything more than 1.5mm
My main usage for them has been when extending short cables in a back box, where they can be checked.
They do take some practise to get the angles right for a tight fit, so I can see how they could be poorly fitted.
The new Wago through splices are much easier so they may become the new choice , even if they are a bit more expensive
Reply to Wago or...... in the Electrical Tools and Products area at ElectriciansForums.net
How many and what type of cables do you want to join, Chocbox is the last thing I would use.
The repair kit is actually sold by WAGO for that specific purpose (in the wall repair). I had wondered myself about shrinking individually first...
