Thankyou for your opinions on MFT's. I am in the process of buying a replacement meter for my KT64, which was repaired last year with same selector switch fault coming back.. Meggers 1720 appear to be fixed now, but the 2 wire loop test is apparently still giving incorrect readings??? (comments welcome). Fluke 1652C what do you think about this meter? is it robust? does the loop test take long? is it easy to switch between tests?.... Metrel MI3000 i have heard some good things said but understand the remote test probe is an optional extra, which pushes the price up, not as much as the fluke, but then you think to yourself, pay a bit more and get a fluke?... I know you need to draw a line somewhere, but having a dependable, accurate test meter that is easy to use is just so important that I don't want to spend to much, but more importantly don't want to make the wrong decision... Any advice would be gratefully received.... Regards Paul.
