What type of fuse this is? | Page 2 | on ElectriciansForums
Discuss What type of fuse this is? in the UK Electrical Forum area at ElectriciansForums.net
banny07
I came across this fuse twice. Could someone here let me know what type of fuse this is.? I need to fill EIC.
Thanks. I will inform the customer and mention this in the comment section of EIC.
Only problem then is that it is in black and white that you have removed the fuse!
So your choices are put a dangerous fuse back in, or buy a very easily available 100a fuse bs1361 type 2 and fit that instead which would be far more safe.
I'm not suggesting either as it's illegal, just thinking out loud.
Of course you could contact DNO, which is the correct option.
Why does a loose neutral at the mainswitch need the fuse pulled?
Devils advocate.
With the mainswitch off, no load. Neutral will be at, well, neutral. Nothing. Nada.
Yes, technically a neutral is a live conductor… but voltage test to earth first, and insulated screwdriver.
Reply to What type of fuse this is? in the UK Electrical Forum area at ElectriciansForums.net
    • Friendly
Apart from how you extend all the cables
And with a duff one, it just sits there, not knowing which way to turn, but drawing considerably more than its normal run current.
