What will the outcome be of my assessment? | Page 4 | on ElectriciansForums
Discuss What will the outcome be of my assessment? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Hello all..
I expect my full rewire will be assessed this year by Stroma.
It has been done very well and neatly and ticks all the regulation boxes..... apart from socket/switches heights. These I have kept as existing, approx 1350mm for switches and 300mm for sockets.
I have rang Stroma and they have said that a full rewire needs to meet Part M requirements for these heights. I realise BS7671 553.1.6 doesn't give these heights but Part M does and if Stroma say it has to be then there's no arguing really. Also, even though the vast majority of threads say that a rewire does not need to meet part M heights I believe it does as Section 0, 0.2 says part M applies to new builds and also 'Material alterations' of existing dwellings.
Basically my question is 'could they possible make me change all the heights'? I can't believe they would as that's crazy, but just looking for reassurance. I expect it will go down as a note and be checked for the following year to make sure I have adhered to the heights?
I just took it directly from the Part P document.
I sorter stand corrected. The definition of material change (reg 5), gives 10 examples.
From the online Doc M;
Meaning of material change of use (reg 5), i) the building contains one room for residential purposes, contains a greater or lessor number of such rooms, than it previously did.
I think thats describing alteration or extension?
However, Requirements relating to material change of use (reg 6), does not list i), only change to hotels, institutions etc for application of M1 (access & use).
So give agree with you there.
But then the document bumbles around with not making it less compliant than it previously was or reduction, which I can't decipher! Which was my point really, that Doc M still can apply to an alteration or extension. I still agree that a rewire doesn't constitute a material change of use.
I'll tried to up load that part of the doc, but the screen shot revealed personnel details :oops:. Gardeners weekly & knitting monthly.
This is better;
[ElectriciansForums.net] What will the outcome be of my assessment?
No. change of use specifically means it had one use ie retail or commercial and then became residential. It wouldn't be change of use if you changed the use of a garden into a room!
That just means if the sockets are at 300mm you can't lower them but you can keep them at 300mm or higher.
I was recently on a job where an agricultural building which had been in use as a brewery and is now being converted to a dwelling was being wired for its new use as a dwelling. There was a freelance building inspector on site and I specifically asked him if Part M applied and he said no, put the accessories at whatever height the customer wants. I'm with Stroma too but probably won't be taking them to this one on assessment...!
Your first point, if you read item I) in below, and explain for me?
Your second point, its item 0.4 thats a bit gobbledygook.
I haven't the reference to back it up, but I would have thought that brewery to a dwelling job would definitely have triggered the new build clauses for outlet and switch heights. If it didn't (as that inspector says) then is he also saying he doesn't need to see the latest domestic insulation or smoke alarm standards? Just to make a point :) .
Reply to What will the outcome be of my assessment? in the UK Electrical Forum area at ElectriciansForums.net
He said something about a fused something as the lights hardly take anything .. I told him was mostly cordless tools so just chargers ..told him...
ok cheers for the help lads
