What will the outcome be of my assessment? | Page 3 | on ElectriciansForums
Discuss What will the outcome be of my assessment? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Hello all..
I expect my full rewire will be assessed this year by Stroma.
It has been done very well and neatly and ticks all the regulation boxes..... apart from socket/switches heights. These I have kept as existing, approx 1350mm for switches and 300mm for sockets.
I have rang Stroma and they have said that a full rewire needs to meet Part M requirements for these heights. I realise BS7671 553.1.6 doesn't give these heights but Part M does and if Stroma say it has to be then there's no arguing really. Also, even though the vast majority of threads say that a rewire does not need to meet part M heights I believe it does as Section 0, 0.2 says part M applies to new builds and also 'Material alterations' of existing dwellings.
Basically my question is 'could they possible make me change all the heights'? I can't believe they would as that's crazy, but just looking for reassurance. I expect it will go down as a note and be checked for the following year to make sure I have adhered to the heights?
If you read part M carefully you will see what the applicability of the sockets is with respect to material alterations.
[ElectriciansForums.net] What will the outcome be of my assessment?
where M4(1) is the regulation dealing with premises where people with reduced mobility may visit.
Regarding "material alterations", it's self explanatory. Material meaning "has relevance to the compliance status" and alteration means "change made". So if you move a socket it's an alteration, if you keep it in the same place it isn't. So you can't move the socket down but you can move it up or keep in the same place.
Regarding "new dwellings" those would be either complete new build, or change of use e.g. from office or retail to domestic accomodation.
In summary - rewires/extensions - same or better. conversions from non domestic or complete rebuilds - fully compliant heights.
Hope that helps!
Forget it and make no mention of it. From the posts on this thread I see no one stating the heights apply on a rewire, it is unanimous.
Thats pretty much what I've decided.
I'm going to use the rewire as its a god damn art work and they damn well better praise it rather than batter me for socket heights!
Forget the Assessor, you know whose opinion matters the most - pics please :) .
I don't usually post pics as you know you'll get a battering as theres always something glaringly obvious that you've missed, but heh ho.... here goes :eek:.
Before (1)
After (1)
Before (2)
After (2)
Before (3)
After (4)
Always struggle to get the neutrals looking neat!
Ps.. I've written off to Stroma now, specifically mentioning 0.2 and 0.11 of Part M regarding 'material alterations' and the fact that a rewire isn't classed as a material alteration. I'll let you all know what the official response is.
Well, what happens in the scenario a rewire where the customer does not want chasing of walls you are doing like for like rewire. If you had to do surface ie mini trunking you would be left with the old boxes at the old hights if you were to do Part M.
Thats not quite true as I'm aware. The Documents apply to all building work, with some exemptions.
Part M would not apply to an alteration or extension to an existing dwelling. However, as I and others have already suggested a major refurbishment of a dwelling, e.g. completely renovated for example, requiring structural change, then Part M and others may be applied. There are 'limits on application'.
To say it applies only to new builds, is not quite correct IMO. Sorry if I'm being picky.
I think we are all agreed that in this instance a rewire does not constitute material alteration. But HHD will need to discuss this with his scheme. Its his assessment with them.
I just took it directly from the Part P document.
In recent years I've used several rewires for my annual assessments with Stroma now non of which were questioned over the socket and switch heights. The only times I've complied with Part M regarding socket and switch heights is on new builds and properties which have been gutted back to brick inside and likely to be used by disabled persons i.e. ground floor flats, bungalows etc. I shouldn't worry about it unless of course your assessor turns up in a wheelchair.
Reply to What will the outcome be of my assessment? in the UK Electrical Forum area at ElectriciansForums.net
He said something about a fused something as the lights hardly take anything .. I told him was mostly cordless tools so just chargers ..told him...
ok cheers for the help lads
