Wiring up 8 x 230v 35w downlights
Hi all, this will be my 2nd post as a member.
I want to replace my existing pendant lights in my living room with 8 x 35Watt GU10 led downlights. Was just wondering about the best method of wiring these together so they can be operated from a two way dimmer switch. Ie: In two groups of four.
Really appreciate any help with the above.
Cheers! :)
it's a big room 22 ft x 10ft. my method has always worked for me and customers have been happy. nothing worse than installing lighting to have the customer ask you for the loan of a white stick or a torch.
Hardly a big room. You must be fitting garbage lamps or fittings then. 12 @ 520 Lumens per lamp is over 6000 Lumens, and for a Lounge, only thing Customer will need is Sunglasses and a dimmer would be an absolute must.
I would agree that having the lights on 2 switches is a sensible idea - who is going to be doing the plastering?
EDIT : Is your lighting circuit RCD protected?
If not changing the switching, why does it need to be?
Things must be very different in England to here, 3m * 7m is not a big lounge, why on earth would you want the lighting switched in 2 zones especially if using a dimmer? 1 dimmer for all lamps and a nicely consistent lit room. Failing to see the benefit of having half of it switched off at all tbh.
custie86,
w0z,
