No bee in my bonnet with you at all, just think (as somebody else has stated) you were rather quick to imply (not with words but you and others know what you meant)that Electrical Trainee are to blame for the five fold increase in cu fires.
The select committee thing, well your rather forceful here with words & views but on the day you were more Percival than Rommel & that is Just my view. Could I have done better? who knows but I didn't put myself up for it but you did , so hats off to you I suppose.
Real issue with you, how can I have an issue with you when I don't know you from steptoe?
what I do have is my own opinion (as you & others also have) & from what I see there does seem to be some Electrical Trainee (that normaly rolls into DI) baiting/bashing, for the woes & downfalls with in the trade & a minority here soon jump on the bashing bandwagon.
Yes some of their work is way below expected standards, but the same can be said of some time served individuals & larger contractors for example, a few months ago I replaced a db in a fire station due to a burnout/loose neutral on the main switch that was less than a year old, installed on a refurb by an Approved contractor.
The casing flared & scorched/sooted the wall, not a Electrical Trainee or DI in sight, but it was an electrical fire in a cu.
Because its not a domestic job done by a Electrical Trainee I suppose it doesn't count in the five fold increase headlines?
Meaning I watched it & had my own thoughts about it & what was said.
How about......
If you have issues with Electrical Trainee & the like why not start shouting about the root cause, such as the training offered by some of these training companies that they then purposely aim at those who think 5 weeks is enough to become an electrician & yes that includes the likes of the NICEIC & some forum sponsors that can be found on electrical forums.
Then (and this is one of the tings I took out of the select meeting) how about asking why is the whole part P fiasco not being policed/enforced, yet use a logo when not entitled to you'll get hung drawn & quartered! That was hardly mentioned by the trade side of the room in the meeting.
Will you be using your torque drivers for every connection? I mean every socket, switch or other terminal?
I am all in favour of progress and improving safety or using new tools and methods. But I think it's a poor showing if an electrician can't tighten a terminal for copper cables without the aid of torque drivers, especially the little terminals in a domestic CU.
Would imagine that the issue that is warranting their introduction has as much to do with over tightening them as under tightening them.
will do f all on jobs like this thoughTightening screws and double checking they are tight is obviously not part of the Electrical Trainee course hence the mass introduction of torque drivers,
They've got no hope of learning how to use a torque driver properly then!
