Steady Steve
Trainee
I've just started my training and am interested in what tools are essential when first starting out. Is the torque screwdriver regarded as one of the useful tools in the toolbag? Thanks
Discuss Do I need a torque screwdriver set? in the Electrical Tools and Products area at ElectriciansForums.net
That's good to know. There seem to be so many tools available - of varying specialisation - that I only want to look at those that are necessary. A cable stripper is something that I did recently purchase.No probably not.I had one for 3 years and used it twice, then sold it. For some specialist applications then torque tools are required but for the majority of the work I do I'm comfortable I've tightened stuff correctly with a normal screwdriver
Thanks, now that's a very reasonable list!If you're starting to gather up tools, I wouldn't be too concerned about a torque screwdriver just yet.
Pliers, shears, side cutters, screwdrivers would be the basics to start with, then increase that range of hand tools depending on what sort of work you find yourself doing. Maybe add a pair of 8" grips to the list of essential tools - I hate them, but have to conceed they cover a lot of uses.
That's useful to know. I should have tightened a few terminals by the time my training takes me to consumer units.The only thing where a torque driver would need to be used is a consumer unit, where there is a Nm value stated for tightening terminals.
If your just starting out, you won’t be doing many of them.
It is argued that too tight can be as bad as too loose, but as you progress, you’ll get a sixth sense with a manual driver whether it’s too tight or loose….
But then, your “tight enough” may be 2Nm, or 3Nm where the stated is 2.5.
I'm glad that having a torque is not obligatory, and so I'll focus on having a couple of plus minus - I've heard it before and it makes sense now.I'd have a a couple of "PlusMinus" screwdrivers for consumer units much higher up the list than a torque one.
might have a couple of +/- spare. if i can find them you can have them cheap. I'm just outsideof Northwich, so easy pick upif I have them.I'm glad that having a torque is not obligatory, and so I'll focus on having a couple of plus minus - I've heard it before and it makes sense now.
Very good point!You might not need a torque screwdriver for day to day use, but I'd suggest you need one in your toolbox once you are completing jobs like consumer unit changes. So that you have the means to tighten terminals to manufacturer's specifications, even if you think you can do it accurately enough without.
Years ago, my college tutor told us of a court case, where an electrician was asked about the content of his toolbox, and it didn't include a torque screwdriver. He was then asked how me managed to tighten the terminals to the correct values. He had no defence. Don't recall the rest of the details (I think something caught fire).
I have an impact WRENCH (1/2") that I use constantly for deep socket 15/17/19mm work in generator busbar chambers, turns a 2m job into a 1s one - however - it's a Makita one with clever adjustable modes, so it's set so that as soon as it starts to actually impact it shuts off automatically so that you have more control over the final few 1/4 turns. Likewise it senses when the nut is loose and stops spinning so that you don't end up with it flying off. But I can't think that I've ever used a motorised tool on a standard terminal screw, or fixing plate, EVER in my now 34 years of sparkying. As the old saying goes.... "It's only fun until someone (or thing!) gets hurt"Another factor is stuff being poorly done and often damaged on assembly is monkeys using an impact wrench. Except for some very specific tools, NEVER use a power tool on electrical terminals! Most impact drivers will, even at the lowest setting, hammer the faster home to a much higher torque that most can cope with. Typically the only ones likely to survive are going to be M8 or larger studs, etc. A moment's carelessness with my own impact driver (Milwaukee M18FID2) resulted in me shearing a M6 roofing screw when assembling cable try, so I am not joking!
Having said that, my impact driver is a most excellent tool to have (though not the cheapest) for drilling with the hex-shank bits, using the 20mm - 32mm hole saws for glands, etc, and for mechanical assembly/disassembly on larger wood screws or bolts as it really gets the job done quickly.
I have a selection of torque wrenches and screwdriver-like drivers for mechanical work and so I use them when needed for big terminals.There is a modern bike tool that does 1-8nm and costs £39 but that is getting too close to the Toolstation £64 Draper 1-5nm VDE offering to be worth scrimping on.
So don't do what I did!
Makes sense when the tool is able to deliver the torque control needed for the job.I have an impact WRENCH (1/2") that I use constantly for deep socket 15/17/19mm work in generator busbar chambers, turns a 2m job into a 1s one
Ah, you mean the YouTube attentionwhores ?Most 'electricians' these days use an 18v impact to do consumer units , in fact the 18v impact seems to be used for pretty much everything
If you are a cowboy electrician !!!!Most 'electricians' these days use an 18v impact to do consumer units , in fact the 18v impact seems to be used for pretty much everything
Way back a few years ago we had really bad 'proper' snow down here and nobody could get anywhere as it's all small roads that get gritted last, I had some housecalls to do, just 10 min maintenance type stuff and I seriously considered riding out on my then step-daughters horse to go and get to them, thought it would be a nice novelty piece for the local rag - 'the electrician that always delivers no matter what' kind of nonsense. Then all the Cowboy Electrician potential jokes occurred to me so I refrained!!If you are a cowboy electrician !!!!
Not so sure I'm with you on that one - a pet hate is when the casing wants to split on a device terminal when you actually properly tighten it, even by handYou'd have to really give it some with a screwdriver to damage a MCB
Reply to Do I need a torque screwdriver set? in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
