100ma RCD | Page 3 | on ElectriciansForums
Discuss 100ma RCD in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Isn't spraying a flammable liquid onto a area where arcing is going to be present something of a fire risk?
Better to use some teflon cycle lubricant in a pump not an aerosol.
Good point, it is flammable liquid, better to use non flammable lubricant
Reply to 100ma RCD in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Regulations notwithstanding, the only thing in those pics that is likely to be affected by sheep is the trailing flexibles on the ground from the...
As per above from Dave. Swap to a 63A outlet and problem goes away. What gets plugged into it is not part of an inspection.
