Allo, allo....J'oublie. Je ne comprends pas, tres bien. Avez vous une cuppa?Bonjour Messier, quelle heure est-il? Ou sont les toilettes?
Got a Grade 3 for that!
Got a brew for that.
Discuss 2391 V NICEIC - Whats the point in 2391?? in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
Hi you are correct, so our friend has been mis-informed. You cannot sign off work unless you are a member of any of the schemes mentioned, but you cannot be a "qualifying officer" unless you hold BS2391 or the easier cheapo version of 2394 and 2395. C & G introduced the latter qualifications, because 2391 was too dificult to pass. What does that say for 2394 + 5 holders?If I understand correctly, to do electrical work in accord with BS7671 one needs to be competent. So the qualification is "competence". What is competence, I hear you ask? Being assessed and accepted by a Competent Persons Scheme is one measure perhaps ( ). I can't speak for the Nice Guys, but with my mob they judge competence for EICR is shown when you have practical evidences and a training qualification (2391 for example).
Hi Andy, you may be able blag your way through filling in a certificate, but without scheme membership, or qualification, no-one will accept it . Building control aren't going to accept a cert from a non qualified person, and insurance companies will just send it back without a scheme membership number.You CAN issue a certificate for your work with or without testing and inspection quals, and with or without scheme membership. Like I said it's notifying work that is made easier with scheme membership.
Really? Any evidence of this? Or is it well they will try anything to get out getting things done mentality?Hi Andy, you may be able blag your way through filling in a certificate, but without scheme membership, or qualification, no-one will accept it . Building control aren't going to accept a cert from a non qualified person, and insurance companies will just send it back without a scheme membership number.
If you are a "qualifying supervisor" signing off certificates, but you aren't qualified to fill in the certificate, how does that work?I am a QS but do not hold the 2391.
You need to be competent only.If you are a "qualifying supervisor" signing off certificates, but you aren't qualified to fill in the certificate, how does that work?
I bet you think HSE won’t allow you work on ladders too don’t you?If you are a "qualifying supervisor" signing off certificates, but you aren't qualified to fill in the certificate, how does that work?
Hi Andy, so what you are saying, is that because you are a qualified electrician, you are automatically entitled to fill in a cert to cover the work you have undertaken. Why do you think that BS2391 was introduced? Its a level above 1st and 2nd fix installation. To gain 2391, you need to be able to understand the readings that your test equipment has just given you. You need to be able to correlate the readings, to what might be expected. I'm not trying to decry people from thinking that sparks should be confident in what they have installed, but 2391 gives you lots of mathematical equasions that can qualify your readings. Its not that simple. Thats why 2391 exists!I was talking about filling in a certificate to BS7671. This has nothing to do with building control or insurance companies. Anyone who has done a proper electrical training should possess the competence to be able to test and cert their own work. Extra quals for testing and inspection are not necessary.
I juggle 3 cordless drills whilst hanging on to a 2 metre wooden trestle. lolI bet you think HSE won’t allow you work on ladders too don’t you?
Reply to 2391 V NICEIC - Whats the point in 2391?? in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
