90mm Cut Out Downlights | on ElectriciansForums
Discuss 90mm Cut Out Downlights in the Electrical Tools and Products area at ElectriciansForums.net
Walsall
Hi guys. I went to a property yesterday as one if the current downlights burnt out and damaged the circuit. However when I took out one of the downlights I noticed how big the cut outs were ..90mm. They were in fact too big for the lights actually in there.
Can anyone recommend some Fire Rated downlights that would fit a 90mm cut out? They need to be IP44 as there going in a bathroom out of zones.
Cheers
Andy
90mm hole isn't that big. Fitted a couple of JCC GU10 cans on Monday that specified a 85mm hole.
Try looking at tiltable fittings, rather than standard ones. These usually need a larger hole, and is what I normally use, for the simple reason that I can get my hand through the hole to find the cable left there in first fix.
Reply to 90mm Cut Out Downlights in the Electrical Tools and Products area at ElectriciansForums.net
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
OVIA IBEX 5W EMERGENCY LED SELF-TEST NON-MAINTAINED DOWNLIGHT
Thank you, it is always good to hear another suggestion :)
I recommend the Manrose Humidistat timer: Humidity Sensors for fans -...
Is your Quinetic a dimmer switch? If so, have you ever used it in conjunction with any (dimmable) LEDs before, and how did it behave? Did it dim...
Trending Electricians Tools
New job, new tester; Megger 1741+, those that have one; anything good/bad to report? Work also trusting me with a Flir E5 magical heat-reading...
95K
Absolutely correct they hold water, shrouds are totally unnecessary. 20s is 24mm spanner, 20 large is 30mm spanner.
45K
If that little thing, plugs your butt, you better eat slowly. 🤣
2 3 4 5 6 7 8 9 10 11 12 13 14
40K
B
I'd say everyone has knowledge gaps in their area of electrical work I know i have quite a few i work on to fill them in
2 3 4
29K
I too have been tempted.. I’m buying for my son. He’s in his2nd year at collage and looking for apprentiship. Sadly it’s almost impossible in my...
25K
Of course. “Ye canna change the laws of physics” EDIT. oh blimey, I just spotted the date of the OP. ? Thank you very much @Lord lee jan You...
22K
Only way to do it in a tight space
21K
The display on the Mft pro is not very durable mine is broken already 😡
21K
Only lawyers , solicitors and dodgy chat up lines charge for picking up the telephone 🙃
2 3 4
20K
J
I'm not entirely certain as it's very tough, but brittle when cold.
2 3
19K
nicebutdim
N
