Alarm control panel | Page 3 | on ElectriciansForums
Discuss Alarm control panel in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I've ordered 10 fuses so plenty to play with. I'll disconnect the battery and pop a few back in see what happens. Is there any way to test the pirs or is it a case of trial and error
Now bell box....again after 5 plus years, the 6v nicad gives up, and you will find it split open.not worth replacing as it takes other components. New bell box time.
Batteries must always be checked, and replaced every 5 years.
As taz says changing the battery is a good start if that don't solve it then just check the pirs one at a time disconnect them and do continuity test between red and black to check for any shorts hope its just the battery then it will be a quick fix for you
Just checking but it will be ac out of the tranformer and dc on the pcb did you have your multi meter set on the correct setting
That's a very good point didn't think about that. I normally do commercial stuff so abit out my comfort zone here so excuse if I miss things. I was using my little multimeter and had it on the dc (just checked the meter) but not sure if I trust it much so fetched my multifunction megger (mft1552). This only gives a second for volts so I presume this can read both?
Dont think a mft would give you a dc reading i would use a multi meter, to check if your multi meter is working properly just test it on a new battery , any battery will do, a standerd b c or d baterry is 1.5 volts dc , if your meter it working ok ,then had you removed all the load from the panel and have you replaced the fuse without it blowing, if so it sound like the panel will need replacing
Just had a look on the mft1552 manual it says it automatically reads between Ac and dc but will try on the battery. Fuse replaced and hasn't blown but I did leave the battery disconnected through all this would that affect anything?
If you have removed the battery and now the fuse isnt blowing i would say you had a duff battery so maybe worth getting a new battery , it might be that you were not testing correctly :)
Reply to Alarm control panel in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
    • Friendly
Thanks so much for sharing this with us! I’ll definitely take a look, it seems like there are a lot of useful and interesting products. The idea...
hi yes i agree its a final pir circuit with 30 seconds entry and exit programmed in no other detectors on route to rkp tried a different...
These keypads are obsolete and replacements are hard to find, I've replaced loads now with failing displays. Sounds like something isn't...
