Blanks missing from CU in 2 senarios | Page 8 | on ElectriciansForums
Discuss Blanks missing from CU in 2 senarios in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I would 99.9% of the time code a missing blank as C1 and I rarely give C1's.
It's a great big hole with a big piece of live copper behind it which is easily touchable!
What circumstances would the 0.01% occur?
As mentioned earlier I would NOT C1 it as I would pop some spare blanks on to bring it up to standard. I always carry them and it costs minimal pennies and vertically no time.
However for those lazy penny pitchers who wouldn't do this I think a C1 should apply.
Isn't C1 classed as "immediately dangerous" rather than danger present.
Self explanatory definition in my opinion.
If an exposed live part does not have suitable basic protection to prevent it being touched. That to me is immediately dangerous.
No it initially states Danger Present. Later it explains there is risk of injury. Immediate remedial action required. Strangely it also explains Code 2 as urgent remedial action required. What is the difference?
This is the issue I have with how they are defined. What is Danger Present which overrides Potentially Dangerous.
Merlin Gerin and Schneider boards have sliders to energise each way.
If those sliders are off where there are no MCBs, where’s the exposed live conductive parts?
Similarly old MEM DBs have removable ‘Y’ shaped pieces of metal to connect between the MCBs and the hidden bus bars.
Most CUs have shrouds and bus bars which can be cut to length.
So like I said code C2 for missing blanks and code C1 where there is exposed live conductive parts.
This is my point on the Code definitions. Separate Danger Present and Potentially Dangerous, they walk the same path to a hazard. What is Danger Present, something Potentially Dangerous.
I am not sure if you are being deliberatly obtuse but I will play the game with you.
If you read it literally then everything has the potential to be dangerous. If we use common sense it is very obvious what the intention is.
Reply to Blanks missing from CU in 2 senarios in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
There is no homework, and I'll never see these photo again.
Generally it would depend on the circumstances whether the armour is earthed both ends or not, and not just dependent on whether it's 2 or 3 core...
