cutting meter tags oops
sparky-s-w
Hi,
i realise the ilegality of cutting the security tags on meters/fuses etc, and dont expect people to identify themselves as offenders, so Hypothetically
is it practical to call/arrange for the relevent energy supplier to come out every time you change a fuse board/upgrade meter tails?
i have a friend :wink_smile: who has in the past possably cut meter tags in order to change the meter tails, as I (i mean he) didnt have time to mess around contacting suppliers.
do most other contractors do this?, i cant imagine every single electrician would get these tags propperly removed every time. Hypothetically.
After call out to a customer who said there electrics were intermittent I got a lecture from DNO after cutting seal and removing neutral and phase cables from their meter after it was heavily smoking due to a poor connection, it was either this or a fire, they agreed I did the right thing off the record but still went through the speal over the phone ten minites after I did it and contacted them. If I had stood there and waited for them to arrive, the next day by the way, the whole incomer would have gone up, possibly the house as well, I would have regretted not using common sense, which seems to get lost theses days with all the regulation and red tape.
You actually phoned them ?:hurray:
For actions above and beyond the call of duty, you are hereby awarded the xxxxforum Biff55 "seal" of approval
biff55 will provide a link in his next post
Theres only one seal i like.............
I have a friend who has a friend, who cuts through the tails (one at a time of course) with a pair of shears. Strips the end of the tails with said insulated shears and terminates them straight into a twin Henly block. He says it takes 5 minutes and then he can carry on with the cu change and connect his nice new 25mm tails into the block when he's finished. All ready for the supplier to connect into the meter on the next visit if they can be bothered.
He is also wearing a massive tin helmet.
exactly how we always did it before the H&S gestapo started jumping up and down , frothing at the mouth.
I'm training at the moment and one thing I really don't get is how I can possibly do a board change etc if I can't pull the DNO fuse...
If I tell the customer that they're going to have to wait (AND pay the DNO for the privilege) they're going to tell me where to go and give the job to someone else.
Can I realistically bash the old board with a hammer and then say the fuse was pulled as it was necessary for safety reasons?!
you have 4 choices.
1. do it live as post#25. 2. call out DNO for 2 visits to unseal and reseal. 3. pull fuse as the seal fell off before you started. 4. lose the job to some cowboy.
