I find it odd that a back box which cannot normall be touched is considered as exposed, but SWA isn't.
Yes the screws can be touched, and apparently are acceptable to be used to earth the back box, as long as one or more of the lugs are fixed.
Agreed,does anyone still run a separate tail from a socket earthing terminal to a metal wall box ?
No, you should never take an accessory off without the circuit being isolated. If It's isolated then there's nothing that can bite you therefore there is no need for the fly lead
But a circuit is not isolated until it has been proven dead with a suitable tester. So how do you get the tester in to the lightswitch without taking it off the backbox?
By identifying the circuit and carrying out the safe isolation procedure.
Earthing SWA at both ends
Thread Tags
atm84,
Big Sausage,
