help if youve been there | on ElectriciansForums
Discuss help if youve been there in the Australia area at ElectriciansForums.net
i=p/u
Northern Ireland
i have drilled through a waste pipe from a toilet that doesnt be usaed much so isnt leaking, have you evr done this and did you have to cut the pipe and refit piece or were you able to fill with ct1 or anything you consider was good
Depends on drilled location you can purchase joint sections black rubber sleave, but as said depends on location, if you can see the whole take a photo and up load, this would be better for people to try and help. toilet 2.jpgtoilet.jpgif you can get to pipe you can cut pipe then slide this over, or as said up load photo if possible, see what can come up with.
how big's the hole you.ve drilled? if it's only a little one, a bit of silicon. if it's too big for that, say, 20mm. bang a bit of pvc conduit in. remember , you need something to protect the cable from corrosive gases and poo. ( that is, if you are feeding your cable through the pipe. LOL. ) .
If it were me I would get something like a flexible plastic sheet or rubber to wrap around the pipe, also use that "sticks like sh*t" grap adhesive and a couple of straps or big cable ties to hold it in place.
You do not want to plug the hole where the plug will stick up inside the pipe, this will eventually catch and build up what gets flushed and will eventually cause problems.
If you are going to do it do it right, or your might just get yourself in to more ****e, you drilled the whole dont lets start being cheap. as you may get a call back with muddy looking clients at the door. and all the electrics well and truly F UP .LOL
Reply to help if youve been there in the Australia area at ElectriciansForums.net
