help if youve been there | Page 3 | on ElectriciansForums
Discuss help if youve been there in the Australia area at ElectriciansForums.net
i=p/u
Northern Ireland
i have drilled through a waste pipe from a toilet that doesnt be usaed much so isnt leaking, have you evr done this and did you have to cut the pipe and refit piece or were you able to fill with ct1 or anything you consider was good
if you ain't got a jubbly clip, a couple 9" cable ties joined will do the trick, cheaper as well.
Using the correct adhesive, i doubt if you'll have enough time to get the cable ties on mate. That welding adhesive starts working almost immediately, same with our PVC conduit adhesive, try pulling a joint apart a second or two after pushing together!!! It's not glued together but chemically welded. ...lol!!!
Our conduit adhesive is probably identical to the stuff plumbers are using, and airfix modellers lol
Because he has drilled from below into the pipe so the hole is at the bottom, patch it up as everyone has suggested and try to twist the pipe so the repaired hole is at the top so there is no chance of it leaking. If you can't turn it don't worry about it, the adhesive will hold back the crap.
Just to show that I didn't mean anything by my last picture post I've found a couple of pics that you could use as an avatar. It's about time you got one.
or in green.
Reply to help if youve been there in the Australia area at ElectriciansForums.net
