i have drilled through a waste pipe from a toilet that doesnt be usaed much so isnt leaking, have you evr done this and did you have to cut the pipe and refit piece or were you able to fill with ct1 or anything you consider was good
Discuss help if youve been there in the Australia area at ElectriciansForums.net
Until someone blocks it, and pust some chems down to unblock or even a plunger.Silicon,has there is very little pressure in the pipe.
a ffff nnnnnn night mare, the plumber i know aint awnsering
if it's out of sight, just glue a patch on it and cover it up.
LMAO, people are showing what some people would call cowboy tendencies.
Do you feel lucky well do you, did you use 1 or did you use 5 tubes of silicon, well did you.
The thing is you know deep down what to do, but me thinks you are just trying to feel better about doing it wrong, cos others do it, so it must be ok.lol
Reply to help if youve been there in the Australia area at ElectriciansForums.net
