Guest viewing limit reached
correct me if my eyesights wrong tel but isn't that plug on the right you've put up ilegal? tut
Not so much illegal ... just bloody difficult to fit into the sockets in my kitchen.
mind you .. with a big enough hammer ...........
I love a nice grid myself with marked 20 amp switches saying what they do, I like to put the grid on a 20 amp ring main supply for the appliances and have general sockets (ie toaster/microwave liquidizer)on a seperate ring, there are some lovely looking flush plates today which are very nice.
:rolleyes2:
You mean this section....
Limitations of the Miele Service Certificate,
The Miele Service Certificate will not cover costs for repairs
where a fault is due to the following:
7. Repairs or modifications not performed by service agents trained and authorised by Miele.
Your trying to apply a clause that doesn't fit. They are talking about inappropriate servicing by non authorised agents, and were talking about installation method. Any installation method that complies with BS7871 can't be used a a warranty get out clause by the service agent.
1. Improper installation, e.g. non-compliance with relevant safety regulations and written operating and installation instructions.
That being BS7671 in the case of the UK... Now you tell me what fault they could possibly be talking about by removing a plug and wiring directly into a FCU?? Remembering that other EU countries have no plug top fuse.
In other words there is nothing in these warranty conditions legally stating, removing a plug top of this appliance and connecting said appliance in a manner that fully complies to UK standards etc, will or can invalidate a warranty...
And nor will any other appliance manufacturers warranty conditions...
And I think you're trying to explain the clause in a way that simply supports your side of the discussion. You seem to be assuming that a service agent only undertakes a single function 'servicing' but that is just not true, they also undertake installations. That aside, the important word in that clause is 'Modifications'
The item in question will come with moulded plug top, by cutting off said plug you are thereby making modifications to said item. If the person doing the modifying is not trained/approved by Miele then you have just killed your warranty.
Now this bit might strike you as strange, but I would really love for you to be right and for me to be wrong. Miele might be an exception, as they pride themselves on service, and if your going to be paying the sort of cash they ask for their white goods then I should blinking well think so too.
However, I consider insurance legalized theft, and warranties are simply another form of insurance. I just know from previous insurance claim dealings that I have had in the past, that these 'slipperier than an eel coated in fairy liquid' persons with disputed lineage, will screw you at every single chance they get, and if they can twist what is written to work in their favour then they will.
So in summing up, I understand what you are saying and to all intents and purposes I agree, I just think that the world we presently live in means companies, and the bean counters that now run them, will always carp on the little guy from a great height if given half the chance.
And with that waffle over, I'm off down the pub.
Cheers
Cheers
Good post !!
I know from experience hence never cutting moulded plug tops off since I had trouble with an appliance and they wouldn't warrantee it as I had cut off the plug !!
There's a reason they fit moulded plugs you know !! And I can see why..
I'm 100% right!! Contact the consumer rights people (can't remember the official name) or a consumer specialised solicitor. They will confirm what i'm saying is 100% legally correct.
The only way they can void a warranty for removing a factory fitted plug top, is if the connection method doesn't comply with the Codes/Reg's of the country concerned. eg, a dangerous DIY lash up tape job, or connected (via plug top/FCU) with maybe the polarity reversed etc!! ...lol!!
It is normally the authorized service agents that come out with all this crap, not the actual manufacturers. The only reason manufacturers provided a plug-top (moulded or otherwise) in the first place, is because of the EU regulation stating that all appliances must be supplied with a suitable plug top corresponding to the country of final destination!! Contacting the manufacturers direct, or as a last resort a solicitors letter to the service agent etc, will always change their mind pretty dam fast!!
An appliance manufacturer or it's agents cannot circumvent recognised/official codes/Regulations within a given country to suit themselves. They can recommend or even stipulate RCD protection in some cases, they can stipulate a minimum cable/flex size, installation positions etc, but that's about it... It's the same with BS 1362 fuses, it's often stated here that manufacturers state the appliance must be protected by a such and such rated fuse. This can only apply to the size of flexible cable, not to the appliance itself!! BS 1362 fuses are not and never have been designed for the protection of appliances!!
I'm with E54 on this one. I almost always remove the plugs from built-in appliances, as most of them don't leave enough room behind them to fit a sheet of A4 paper, never mind a plug.
None of my customers have ever complained that they've been unable to claim on their warranty. (20+ years)
And for those who say how often do you switch it off, I have personal experience of electric shock from trying to disconnect a faulty washing machine that some twonk had decided didn't need one of those "ugly" isolators. I know which I prefer....
one problem with wiring into a FCU is that you may get a service engineer to the appliance, and no matter how knowledgeable he is on repairing the appliance, he might be reluctant to disconnect from FCU , so you could get called out toi dis. and reconnect after the appliance has been repaired/taken away for repair.
- - - Updated - - -
There are various ways of connecting appliances to the fixed wiring.
The first rule is local isolation and local fusing. The appliance should be designed with overload protection.
Then its up to you how you make the connections. Some kitchen worksurfaces, particularly for fitted appliances do not allow space for a fitted plug at the back so the need for a flex outlet.
I think once you have spent £20k+ on your brand new kitchen with granite work surfaces to plug in or wire in is not an option.
Unfortunately, that doesn't allow for the lack of breadth of competence with some service 'engineers'
I personally like the grid switch assembly where the control and protection for the utility type of appliances are in one place.
Now, there were some concerns regarding the use of several 3kW appliances and the unequal loading on a ring final circuit. Also the rating of the loop in terminals across the input terminals of the 20A DP switches.
However, it will take an electrician to provide a suitable solution.....
Kitchen wiring
Thread Tags
Groombridge,
mydigitalhome,
