MK rapidfix, GAME CHANGER | Page 5 | on ElectriciansForums
Discuss MK rapidfix, GAME CHANGER in the UK Electrical Forum area at ElectriciansForums.net
GBDamo
UK
MK have hit the market first with a lever connection based double socket.
I for one will be all over them as they are not too differently priced, ÂŁ5.99.
When used to spur off on a ring in a metal back box... that's 4 x cpc connections... only 3 wago connections available ?? Or is there capacity for the 4th one somewhere ?
Back box is earthed through the mounting screws.
but if you really want a fly lead, you could terminate the extra cpc on the box terminal.
I was genuinely surprised to learn that they appear to be used only IN ROI. Normally NI wholesalers keep a selection of what's used in both the UK and ROI, but not in this case. Will get a link for you
someone told me that I was the missing link. felt chuffed till I googled it.
They come in 16mm,25mm,35mm.They are also available with brackets attached to the side for fixing to studwork. CEF do them over here.Or you could go online to "electricalwholesaler.ie".
The price for a 16mm single flush box is 65 cent
  • [ElectriciansForums.net] MK rapidfix, GAME CHANGER
Only seen them here in installations from years ago (early 70's maybe), and they weren't great it's a general treat with caution when trying to screw the plate back on. And not aware of any wholesaler that stocks them, CEF certainly don't
CEF in ROI stock them. They told me they can be ordered in UK from other branches. As to their robustness, they are significantly more robust than a drylining box.
Is that a standard backbox or a drying box?
Apologies, they're dry liners. Never read previous convo properly the first time.
I'm fortunate enough to live somewhere where 90% of properties I deal with are stud walls/kit or service-voided so it's very rare I'll use anything other than dry-liners or surface boxes.
Reply to MK rapidfix, GAME CHANGER in the UK Electrical Forum area at ElectriciansForums.net
When I first started, I stripped out a house for a rewire and got my hands on a switch with an inlay and transparent cover. Filled it in with...
@littlespark , thanks for the suggesting using a forum sponsor! @Yellowhammer If you wish to give us a go please do. We offer all forum users 5%...
