Neutrals at switches
G
Guest 004
Went to a job today, twin and earth, and it had been wired 2 plate, which of course meant that all the switches had the neutral taken to them.
WTF, if I had done that in my apprenticeship I would have been kicked off site.
Is this how things are done now, god I hope not.
OK, how about ''not a good wiring method'' Looping through every switch box on a lighting circuit, leaving a neutral joint that is not needed or required is not a good wiring method... I think i've stated other reasons why previously.
Design the circuit or installation properly using if you like the modern connectors like wago's in wago boxes, at down lighter locations and you shouldn't end up with a massive bunch of cables at one location to terminate. Turning switch boxes into joint boxes, to get past what in truth is lighting layout design problems is not a good solution!!
There, ....never used ''Bad Practice'' once!!! ....Boy was that hard for me!!! lol!!!!
E54 is on wind up ,
Guest 004,
Dan,
