Neutrals at switches
G
Guest 004
Went to a job today, twin and earth, and it had been wired 2 plate, which of course meant that all the switches had the neutral taken to them.
WTF, if I had done that in my apprenticeship I would have been kicked off site.
Is this how things are done now, god I hope not.
Ah Ah I like this thread :)
Its been stated 3-plate is standard/good practice and was always taught
When may ask did the "good" practice of looping in at the lights begin ?
It certainly was not standard practice in the 60s
Standard practice in a domestic in the 60s was a junction box under the floor boards with the supply live and neutral,switch cables and one cable at the light,neutrals may have been the exception with a single slung around the roses to loop those lights
Granted the neutrals were not at the switch,but the method doesn't need considering these days because it was old hat
I used to wire and fit star delta starters that had a handle on them, for the user to swing over when they thought the speed was just right,they are no longer used, because, it was a practice that would be out of step with other and better methods available since
I thought I'd stick that in just in case I suddenly became a Domestic installer :D
Times change,wiring methods sometimes also need to change, and us older lot need to put aside the attitude of this is how we did it,so that is the way it should always be done
Its like I said earlier,there is no correct method,we are supposed to design simple and even complex circuits to the best methods available, whatever opinions we may be tied to
I am staying "neutral" :) because there has not yet been one post that gives an electrical reason why it should not be done,rather the 3-plate method seems to be taking a bit of a bashing and the switch method has shown to have more advantages
I was taught that wiring accessory points should not be used as joint boxes, probably the same as you were. And that is the very point!!! They are Not joint boxes and were never designed to be so either.
Again, why is it better to stuff the looped lives into a terminal block in the ceiling than at the switch? 'Wiring accessory points' are indeed to be used as 'joint boxes' otherwise how would you connect the accessory to the wires?
If adding another light would you need to take a feed from the switch???????
if it is to be switched independantly then yes
but if the feed was in the ceiling loop or dodgy j/b then you would still need to chase the wall out to do a new switch , so its 6 of one and half a dozen of the other
I take it it's a 'slow news day' on the forum if this thread is anything to go by!
I'd like to show the quality of work on many of my PIR's where a neutral at a light switch would be treated with the attention and code that it deserves (none).
Was there a reference earlier questioning the quality of the apprenticeship served because of someone's willing to introduce a neutral to a switch position?
I've heard it all now and if you think sticking to a pointless clause of 1960's specifications is engineering free thinking then I'm out of touch!
Loop your neutral according to the characteristics of your light fittings rather than 'how we did it in the good old day's!'
But surely if the switches have been plastered in then you would need to chase two sockets? but if feed was taken from ceiling not the same prob?
If adding another light, you already have a feed at the switch, so you'd just need one more cable to your new light. Otherwise you'd need to take a new feed from another light, and another cable to a switch.
But anyway, I'm not saying loop in at the switch is the ONLY way to do things. You choose which is most appropriate while designing the circuit.
If its changing again before the present standard is sorted,I have had enough,I will stay with the present standard :eek:
What is the present standard by the way :o
:D i have just read my post back :D:D wireless "PIR`S" :D sounds like a drive by periodic. im off to edit my post to wireless passive infrared :D
Guest 004,
Dan,
TrueNAS JBOD Storage Server
