Niceic Assesment | Page 5 | on ElectriciansForums
Discuss Niceic Assesment in the UK Electrical Forum area at ElectriciansForums.net
banny07
Hi all. My first niceic assesment for joining is coming soon. I want to show my friends house where I installed new fuse board and installed new smoke alarm circuit. My question is what should I fill in sesign and construction section? should I leave it blank?
The house have no cooker or shower circuit only three final circuits which have 3, 5 and 7 double sockets as well as two lighting circuits with 7 and 8 lighting points .Third circuit has only three smoke/heat alarms. Maximum demand will be around 26Amps?
Any advice will be very helpful. Thanks in advance
I remember that problem Go to Admin > Engineers, add yourself, and specify which tester you are using in the Test Equipment section. I think you might also have to assign the job to yourself, then it all behaves as expected.
I spend almost two hours to find a way to assign the job without any success. Any advice please
I apologise if this step was not needed.
In my setup, I have added the tester in Admin > Equipment.
I have added myself as an engineer in Admin > Engineer. I have also told the system that I have that tester, again in Admin > Engineer > Test Equipment
Then when I open a certificate, when I get to the "Boards and Circuits" page, you need to tell it which Engineer did the testing:
Click Edit Board, scroll down to this bit:
Then when you choose yourself, the tester should appear too:
Does that help?
Does that help?
Thanks again. It does appear now. I am very grateful for your help.
I think he got it from ebay.
I believe the original source is here:
You need openoffice for those ones (also free).
I think they have PDF versions too.
Unfortunately the forms from that link are still 17th edition. @banny07 's are 18th edition.
Reply to Niceic Assesment in the UK Electrical Forum area at ElectriciansForums.net
Thank you all, yes I didn’t think they do and I have done minor works but the helpline was not very helpful. Got my yearly assessment soon so I...
Although it might appear that I am being elusive with the facts, the point is, only you know what your worth is per hour and how long it will...
    • Optimistic
