No cpc on lighting and no neutral continuity on kitchen ring | Page 10 | on ElectriciansForums
Discuss No cpc on lighting and no neutral continuity on kitchen ring in the UK Electrical Forum area at ElectriciansForums.net
Buckinghamshire
Hi All,
I recently replaced an old rewirable fuse board for metal split load rcd board. However on testing prior to replacement I noted that one of the lighting circuits doesn’t have a cpc. I’ve put this in the EIC for the new board that no cpc for lights, advised client that needs rewiring and advise against metal fittings accessories etc,is this the right course of action to take? They do already have metal fittings on this circuit, Is rcd protection enough to cover this? Also the kitchen ring has no continuity on the neutral conductor, I’ve had all the accessories off to find it but can’t, I’m assuming the break maybe in a buried joint box as the kitchen is an old extension. What’s the best course of action to take regarding this please?
This link is from the horses mouth
18th edition changes - IET Electrical - https://electrical.------.org/bs-7671/18th-edition-changes/
The only thing that jumps out to me about lighting circuits is the requirements for RCD's protecting circuits with luminaries.
I just had a look at that the only thing I could see on Chapter 54 was regarding earth electrodes and protective conductor when more than one source,so I don't know where this so-called new reg comes from
That just says recommended so not an absolute. Also that link is to a private company so has as much weight as helium...
IET Forums - Fuseboard Change with no cpc in lighting - https://www.------.org/forums/forum/messageview.cfm?catid=205&threadid=64580
The impact of the 18th Edition (BS 7671:2018) – Chapters 41, 46, 53 and Regulation 542.2.2 - https://electrical.------.org/wiring-matters/issues/66/the-impact-of-the-18th-edition-bs-76712018-chapters-41-46-53-and-regulation-54222/
The second link is from last year and the proposed changes .
My link above is a summary of what made it into the 18th edition
Reading much IET literature and all the above comments, I am still convinced that as long as all the switches and luminaires are plastic there is no need for a CPC on existing old lighting circuits. After all, that effectively makes it a simple "double insulated" circuit, no different from all the hand-held(!) tools and appliances that are sold now for kitchens, gardens and DIY tools (e.g.) which only have a two-core phase and neutral lead. It would be a nonsense to allow (indeed require!) them to be used, and hand-held when in use, and not allow the same electrical situation when the wiring is hidden and out of reach of the person using it. That would be a complete contradiction in safety.
Appreciate your hypothesis Mate but it only needs one home owner to start sticking Metal decorative switches and fittings up, on a circuit without a cpc, and that blows your thoughts out of the water.
I don't think or believe that a circuit without a cpc, with plastic switches etc, is the same as a Double insulated hand tool, nice idea, but not for me I'm afraid.
the only caveat to that would be to ensure that the faceplate screws did not make contact with metal back boxes. back in the 60's this was achieved by the use of nylon lugs.where a metal back box has been replaced by one with metal lugs, then you have unearthed exposed metal parts.
Remember the wooden switch back boxes Tel?
Reply to No cpc on lighting and no neutral continuity on kitchen ring in the UK Electrical Forum area at ElectriciansForums.net
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
Promised a photo…. Remember, this was working…. And they managed to move in without hitting it…
