Bring back C4. Problem solved.
Probably worded as "no immediate action required "Bring back C4. Problem solved.
I agree.(So if the cables have old colouring we MUST advise the customer to replace [C1/2/3] – no choice)
This would be just plain ridiculous!
you are not producing a report in line with regulation 653.2.
Because Chapter 51 is not the Safety chapter?N/A - why would it not be applicable to verify theCUwiring?
But sadly we are where we are.<A great deal of sense>
But how far back do you go with that argument? When you started in 1969 you could easily have heard someone who'd started out in 1920 saying "I've installed lighting circuits with no earth all my life, and slept soundly". Until 2008 you were no doubt quite happily installing socket circuits with no RCDs, but you've now got an all RCBO installation.One other point I would very much like to make. I have a plastic consumer unit in my home. Its populated with RCBOs. From 1969 when I started, to present day. I have seen, fitted, and reported on installations with plastic throughout. So if I slept soundly from 1969 to 2018 with plastic enclosures. Im not going to start losing sleep because a group of powers to be. Have decided its a good idea. To enclose shoddy workmanship or poor quality materials in metal rather than plastic. And on that, I confess to wearing my heart on my sleeve.
Forgive me but I'm on my soapbox. Please stay with me as this rant has to be said.
Years ago electrical equipment was not built to the same technical spec as today. But !! and its a big but, the build quality was substantial and robust.
I haven't the strongest wrist in the world, but armed with a standard screw driver, I can strip out or split apart a BS 60947-3 main switch with impunity. IMHO something is very wrong. But large manufacturers are churning this stuff out and we have to accept and fit it accepting the BS/EN standards they adopt, without question. When these things melt !! its poor workmanship first, and loose connections secondly. Nice get out clause right there. Electrical demand has increased over the years along with loadings. So now we have larger tails 25mm and above within domestic use. But terminations as currently supplied have to be torqued to prevent damaging these poorly designed pieces of equipment, often leaving terminations under tightened, IMHO. As an example, a DNO meter installer fits a new meter. The tails are disturbed and quickly loosen, (and we all know how easy that is with standard copper cored tails). But the consumer units not in the DNOs remit. His connection are ok, the rest is the home owners problem. Not his fault, because if the terminations were doing there job, it would take a lot more than a bit of movement to loosen them, again IMHO.
Anyway !! A Spate of fires is reported by local fire departments.
The answer (And I know this has been thrashed many times) Enclose the problem in metal, rather than remove the problem itself. Thereby limiting the affects as and when they occur.
So again, IMHO, when I can tighten a terminal with nothing more than the strength of my wrist, and safe in the knowledge that doing so compromises nothing. (Because build quality is up to the task) Then and only then, will BS/EN for this stuff start to get the respect it use to deserve.
This is by no means exhaustive but its a start, and I apologise for the rant.
Speak for yourself on that one. Since the mid '80s, I've not fitted a single socket circuit without RCD protection. Customer didn't get a choice.Until 2008 you were no doubt quite happily installing socket circuits with no RCDs,
And since mid 80s I have been telling young sparkies, DO NOT tell your customers 30ma rcds protect you from electric shock.Speak for yourself on that one. Since the mid '80s, I've not fitted a single socket circuit without RCD protection. Customer didn't get a choice.
Some early ones were whole board 100mA RCD/main switch, but as soon as I realised the problem of one out/all out with this arrangement, and the effect of earth-neutral faults, I switched to dual RCD boards, usually 100mA for lights, water heater, etc., but all circuits with a socket, on a 30mA, before changing to all 30mA in latter years.
I've never heard anyone say that RCDs protect you from electric shock.And since mid 80s I have been telling young sparkies, DO NOT tell your customers 30ma rcds protect you from electric shock.
Because they don't.
And if you don't believe me, you haven't been on the end of a live cable connected to one ?
They can prevent death, maybe ?? sometimes ?? Depends on the condition of your heart.
Additional or enhanced protection I will go with, but these days there over rated and in danger of being relied on more than maybe they should. But as said when I hear people say they prevent you from getting a shock. I think don't make those kinds of promises please !! ?
Just wait until the RCBOs with built in AFDD modules become mandatory in the 19th editions Titanium enclosed CUs!!
You will see people getting loans out to pay for those bad boys ??
They (if working) may well protect you from electrocution - that's not the same as stopping you getting a shock of course...I've never heard anyone say that RCDs protect you from electric shock.
Anyone who says that clearly doesn't understand RCDs.
I sometimes tell lay people that it's the thing that'll stop you from dying if you touch a live wire, you'll still get a shock but it probably won't kill you!
Next time your in a wholesalers full of Sparkies.I've never heard anyone say that RCDs protect you from electric shock.
