Renovated house low r2 readings ! | Page 4 | on ElectriciansForums
Discuss Renovated house low r2 readings ! in the UK Electrical Forum area at ElectriciansForums.net
Soulsurfer
Channel Islands
Just been sorting out a right mess during a house renovation and tests on newly installed ring final are r1 0.35
rn 0.35 & r2 was expecting around 0.58 but had consistently 0.00 Ohms.
MFT was zeroed again from scratch and was still giving a zero resistance reading
Almost all cable is new and IR tests all perfect. Any ideas ? Thanks
I'd disconnect the 13A sockets each side of the CU and then measure R2 end to end from each socket. One test round the ring. The other test to and from the CU. With the CU CPCs for the RFC still disconnected at the CU.
That should give a sensible remainder of ring R2 and isolate the issue in the cables going to and from the CU.
You may need a wander lead of course.
Ehhh? Soulsurfer has found the 'fault' :)
Carrying out tests on new builds we have been carrying out, get first test cert over from sparks on site LL & NN look good earth way down low, then remembered metal walls caddy straps light circuits ect.
Few days later same site different sparks phone call same as above been checking everything he tells me I mention parallel paths & phone goes silent the penny drops oh S...t of course.
Not quite as low as fist post but quite low.
See it on the test sheet kitchen all good block walls, tin in the up & downstairs rest of house so 2 rings affected.
Extended most of the circuits from old 3036 board to new board and used a box with din top hat mounted creating a huge earth bus bar in effect :rolleyes: felt a right prat
SS, I read this post all the way through thinking what could it be, and you led us on a right merry dance mate! Prat is correct! But we all can't see the woods for the trees every now and then! My initial thought was both legs going through one back box near the CU, with the CPCs joined there, as I have seen that sort of thing before. Well done for, ahem, finding it! ;)
Maybe you could add this to the never have i ever thred , we have all done some silly things in the past , at least what you have done is not dangerous and you found what was coursing your low reading before you stripped the installation down back to its component parts . :)
Reply to Renovated house low r2 readings ! in the UK Electrical Forum area at ElectriciansForums.net
Often, but not always: 543.2.9 Except where the circuit protective conductor is formed by a metal covering or enclosure containing all of the...
I was at the other end of the results spectrum today. As I was driving home I had a call from my "Mrs Richards from Fawlty Towers" lady, very deaf...
