Terminating SWA with Wylex REC Supply Isolators | Page 5 | on ElectriciansForums
Discuss Terminating SWA with Wylex REC Supply Isolators in the UK Electrical Forum area at ElectriciansForums.net
Kent
I need to terminate 16mm SWA 2 core cable in Wylex REC Supply Isolators. Going to be using armour for earth. Whats the best thing to do with the earth. I have 12 of these to install. The only idea I have is to terminate armour on steel trunking then run 2 cores into Wylex REC Supply Isolators. Lastly connect earth back to intake. I'm sure there is a better way, I dont want to use steel trunking unless I have to?
See link below for Wylex REC Supply Isolators
http://www.tlc-direct.co.uk/Technical/DataSheets/Wylex/WYREC2.pdf
You do not want your calculations running to 100a per unit, drop your shower down to 8kw job and oven to 7kw etc etc. you need to be distributing 60a per unit with 200a per phase 3ph incomer.
if you exceed this the DNO will want you to sell your soul for the cost of the upgrade for your mains. People like tony and E54 will tell you of the frightening costs of big supplies.
It's not that a Ryefield is not ideal for the job it's the fact that you will need 12 sets of tails with 12 main switches all crammed into the trunking with 12 16mm SWA's. with a big DB like this then you still have the SWA glanded onto the trunking but the DB does the fusing, switching and doesn't need all of the tails. You can specify them with a lockable door too.
Btw once you apply cable calcs you may find that you may need 25mm SWA, and on 100a you would with out doubt need it.
I'll work on reducing load, but think 60A is going to be a struggle, 100A is everything on max at once, not made any allowances yet.
I think we're close the the optimum soloution, but to confirm; do you still think Ryefield is the correct soloution, or should I be looking at the Hager invictus TPN DB?
Thanks, really appreciate all the good advice.
The hager DB is the cheapest solution by far and would greatly reduce install time, the Ryefield is expensive on the grounds it will also need a hell of a lot of tails and 12 x main switches.
Don't forget when working out max loads you need to apply diversity.
There is no way a bedsit would come even close to 60a let alone 100a, my 4 bed house hasn't ever tipped 50a
I agree, it sounds mental. I have a family of 5 with loads of high power stuff and never tripped my 60A. I'll research Hager idea then post my loadings, see what you think.
If I can get down to 60A I can consider T&E again, could I put RCD in Hager?
Sorry to say this matey, but with so many questions "up in the air", it does sound like you need the input of somebody with more experience, or you could find yourself in the poop big time.
Sparky got whisked away for surprise holiday, he'll have to have final sign off as its his name on the certificate, but want to get plan ready to discuss on his return as need to crack on.
No, T&E submains in flats isnt a good idea, because you then have the issue of discrimination between the sub RCD and the RCD's in the CU. I stand by the 250a DB and SWA being the most cost effective method.
I Echo what Murdoch says, i dont mind helping and giving advice so you know the best course of action to take, a informed customer is never a bad thing. The works proposed isnt particularly difficult and it certainly isnt rocket science, however, it is extremely difficult to do it well!!. and if you do make a cock of it then the kind of total load were talking about normally equates to a big fire.
To summarise: Cut out - Hager 250a DB- 63a sp mcb type c- 6" galv trunking- SWA .........Simples
Just had a look at Hager, looks good and probably not much more than original idea. But I don't understand how it works. Plan is to use it as sub main. So main intake to 12 meters, then out of each meter into sub main before going off to each CU.
Hager looks like single 250A in then 12 60A out.
What am I missing ?
Another ficticuous sparky !
I've tried to ignore your constant nit picking which adds no value to this thread, but your last comment is too much. If you care to research compulsory HMO licensing you will discover it is impossible to get a licence without a certificate.
If you have anything to add to this thread of value please do so, but otherwise please keep your negativity to yourself.
Reply to Terminating SWA with Wylex REC Supply Isolators in the UK Electrical Forum area at ElectriciansForums.net
You would treat it as a TT installation.
Yes like that - fitted last week 😂
