Guest viewing is limited
Huge problems now
Changed all the fittings etc and this breaker stayed on for a full day but now it's tripped again
wtf is going on ?
Now im told its when the kitchen light is switched on.
If I isolate the feed to the kitchen light and the kitchen light circuit is faulty will it still trip ?
no, if you completely isolate it it wont trip, if it is that, what type of fitting/s is/are they ?
Found a problem with a socket circuit.
Do you think this could cause the 6amp breaker on the lighting circuit to trip if the N is connected on the N bar with the rest of the circuits
Saying all this tho I did replace the old breaker and it seems to have tripped again.
But when I put a new breaker in it still tripped but this was befor I replace the lighting fittings etc
Could be a new breaker and fittings !
Not so sure tho as the circuits all test out fine
Just cant get my head around this as it tests out fine and is not overloaded in any way AGGGGGGHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
Yeh I had a lad test it he says the same cant understand it
Only things I can think of is
1) Breaker
2) Fault on feed to a 2 way to kitchen light
But then Im told it happens even when they in bed
AGHHHHHHHHHHHHHHHH
House is very damp tho ,,, could this be the problem ?
That wont help me lol
this problem only trips when the kitchen is switched on
for example:1 she woke up switched hall lighting on then switched kitchen light on then after a few mins it tripped.
for example:2 she walks into kitchen turns light on and it trips after a few mins.
for example:3 light works for a good few hours then trips breaker.
Lost me this as it tests out ok
Tripping 6amp breaker
eco-tech,
eco-tech,
