TT system | Page 4 | on ElectriciansForums
Discuss TT system in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
He's off to Hong Kong, nobody has any regs there
You would be very wrong in making that assumption!!! All public buildings and the prestige buildings in HK are built to to BS standards or higher specifications!! And as a SAR State remains very much still following those BS standards. Now China is a whole new ball game all together, but again public buildings are generally built to higher international standards....
Sparks,
Leaving aside this interesting debate on tt systems.
Are you sure that the volt drop is ok bearing in mind the original 150m from the main intake then 300m to your socket.
What size cable are you running the feed from the house?
Reply to TT system in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all. Try to keep this nice and short. Had an EICR fail on a health centre due to corrosion on main supply which was causing high Ze values...
It's not the same scenario, though. Tails more than 3mtrs can be overcome by using a fused switch and rcd board, whether the earthing system is...
