Discuss What on earth is this attached to a consumer unit in the Talk Electrician area at ElectriciansForums.net
Nice Gaff though!There is a garage but that has its own consumer unit ... for context - this is the house on right move.
Is that not a Sangamo time clock beside the digital meter?I stupidly didnt take a snap of the instructions, was on a flying visit. The brand suggests its for or from a caravan oddly...
I took these other pictures though and could not identify a trip nor the reason behind there being both a digital and analogue meter. This combined with the mystery timer has us very confused.
View attachment 31746View attachment 31747
MK sentry CU with all merlin gear :rockon2:
They are actually the correct breakers for those boards, MK breakers at the time were merlin C60 but with MK branding put on the front. The earlier MK LN type MCBs were Siemens rebadged
That's what I thought!Is that not a Sangamo time clock beside the digital meter?
The numbers 1 to 7 at the bottom of the display suggest it could be some kind of 7 day timer. I'd be up for pushing the 'menu' button and seeing what options it offers you, or if it has an override button on it see what comes on when you operate that. Alternatively your "electrician" should have been capable of identifying what it does from what circuit it is on and possibly which direction it goes off in.Hi, I am im in the middle of buying a house and came across this odd thing that one electrician cannot identify, Its hard wired to the consumer unit... any ideas?
My first impression was that it could be an energy meter to tell you how much energy you're using. Is this a possibility?
Get an electrician that can recognise , a basic din rail mounted electronic time clock.....Hi, I am im in the middle of buying a house and came across this odd thing that one electrician cannot identify, Its hard wired to the consumer unit... any ideas?
Reply to What on earth is this attached to a consumer unit in the Talk Electrician area at ElectriciansForums.net
