Wiring a 5 bedroom house | Page 9 | on ElectriciansForums
Discuss Wiring a 5 bedroom house in the UK Electrical Forum area at ElectriciansForums.net
omoeko
London
Hello Everyone,
I am not sure of the etiquette here on the forum, but I would like to start by extending warm greetings to everyone in the house. This forum is very useful for me and I have learnt a lot from it.
I would like to ask a question, its about the list of materials required to wire a 5 bed house. I have the list below, and would like to know if its correct etc.
3/4 double sockets per bedroom, and everywhere will have spot lights apart from the bedrooms. I also plan to use a double electric oven, which is rated at 4,400W and hence a 6mm cable needs to be used. The distance is about 10m from the board to the kitchen. Below are the oven specification.
Energy efficiency class (2010/30/EC) - cavity 2 : A Energy consumption per cycle forced air convection - cavity 2 (2010/30/EC) : 0.80 Energy efficiency index (2010/30/EC) : 112.9 Energy efficiency index cavity 2 (2010/30/EC) : 94.1 Electrical connection rating (W) : 4400 Current (A) : 20 Voltage (V) : 240 Frequency (Hz) : 50
Description Quantity
Non fire rated spot lights (Lounge) 10
Non fire rated spot lights (hall by door) 4
Non fire rated spot lights (family living area) 12
Non fire rated spot lights (Kitchen) 8
Non fire rated spot lights (Upstairs landing) 6
Non fire rated spot lights (Downstairs toilet) 4
Non fire rated spot lights (Utility room) 2
Bathroom spotlights (Upstairs bath) 6
Bathroom spotlights (Upstairs Ensuite) 4
External spot lights for outside 6
Pendant light 8
Smoke Alarm 2
Heat Sensor 1
Extractor fan 3
12/15 way board with MCB's 1
Kitchen Extractor Chimney 1
Shower shaving socket 2
Isolator for extractor fan 3
1.5mm brown cable 100m
1.5mm blue cable 100m
1.5mm GREEN/YELLOW cable 100m
3 core flexible cable 50m
2.5mm 3 core cable 200m
1.5mm Twin and earth cable 200m
2.5mm blue single core cable
2.5mm brown single core cable
Earth bonding
10mm green earthing
2 gang switch 4
3 gang switch 1
1 gang switch 8
1 gang switch white 2
Outside floor light 2
Fused spur with neon light 3
13amp socket plug 2
Double socket chrome 35
Double socket white 6
Cooker switch chrome 1
6mm cable for cooker 10M
6mm armour cable for garage 12m
Coaxial cable for Tv 50m
Coaxial socket for satellite 2
Electrical trunking 75 x 50mm - 2.4 metres 2.4m
Carbon monixide detector 1
50 pieces of open Grommet 25mm
2 Gang External plug socket 1
I'm done.
Don't go.. These posts are fun.. DIYers are always fishing for info...
Don't you know, you don't need an electrician to wire up stuff... if it doesn't go bang then jobs a good un.....
I'm done.
If he knew what he was doing, he wouldn't have been wiring the pendants in singles in the first place. Going on what you've written, neither you or your Electrician (If he exists) have the first clue what your talking about. Your just fishing for information.
I'm done.
To the OP, not you Andy Don't think we are being harsh on the UE unidentified electrician, come clean mate you will be doing the work wont you? you're the mystery Sparky, if this job actually exists, you need to call an Electrician pronto, not angle for info on this forum, Ive enjoyed our little chats but enough is enough, get real. I think I'll join Specialist and be done as well.
Awww... You are such a nice bloke. When others are scared to comment on the list. At least you are staying. I repeat, i am not doing this myself, I would also not mention it again.
I will however get to the bottom of it even if nobody helps.
OP.... You'll be happy to know, I'm STAYING..... I won't abandon you like the others. Just need some popcorn....
So come on OP, why don't you ask your "sparky"?
Surely he must be aware of the full spec as he must have quoted against it ......... ...... ........... ........... ............ .............. after all, nobody agrees a price to do a rewire without knowing the full or agreed spec do they?
Reply to Wiring a 5 bedroom house in the UK Electrical Forum area at ElectriciansForums.net
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
